Ana içeriğe geç
Onkyo TX-800 Power fuse Replacement
Neye ihtiyacın var
  1. Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: adım 1, 3 resimden 1. Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: adım 1, 3 resimden 2. Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: adım 1, 3 resimden 3.
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Onkyo TX-800 Power fuse Replacement: adım 2, 2 resimden 1. Onkyo TX-800 Power fuse Replacement: adım 2, 2 resimden 2.
    • Remove the top screw on the back panel.
  3. Onkyo TX-800 Power fuse Replacement: adım 3, 2 resimden 1. Onkyo TX-800 Power fuse Replacement: adım 3, 2 resimden 2.
    • Slide off the case to expose the internal components of the receiver.
  4. Onkyo TX-800 Power fuse Replacement, Power fuse: adım 4, 2 resimden 1. Onkyo TX-800 Power fuse Replacement, Power fuse: adım 4, 2 resimden 2.
    • Locate the fuse.
  5. Onkyo TX-800 Power fuse Replacement: adım 5, 2 resimden 1. Onkyo TX-800 Power fuse Replacement: adım 5, 2 resimden 2.
    • Gently wedge a small screwdriver in between one side of the fuse and the contact.
    • Remove the fuse with your thumb and forefinger.
  6. Onkyo TX-800 Power fuse Replacement: adım 6, 1 resimden 1.
    • Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Michael Lady
271 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S27G92
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
Thanks for clear instructions!
Andy Dersch - Yanıt
Thank you!
There are no Onkyo repair centers to go to.
obobooks - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 33
Son 30 gün: 120
Her zaman: 18,657
