Ana içeriğe geç
OontZ Angle 3 Motherboard Replacement
Neye ihtiyacın var
  1. OontZ Angle 3 Motherboard Replacement, Back Case: adım 1, 3 resimden 1. OontZ Angle 3 Motherboard Replacement, Back Case: adım 1, 3 resimden 2. OontZ Angle 3 Motherboard Replacement, Back Case: adım 1, 3 resimden 3.
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. OontZ Angle 3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
    FixBot'a Sor
    Yorum Ekle
  3. OontZ Angle 3 Motherboard Replacement: adım 3, 2 resimden 1. OontZ Angle 3 Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
    FixBot'a Sor
    Yorum Ekle
  4. OontZ Angle 3 Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. OontZ Angle 3 Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. OontZ Angle 3 Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    • Locate the soldering connections for the battery on the motherboard and the wires for the speakers.
    • Use the soldering iron to disconnect the battery wires from the motherboard.
    • Use the soldering iron to disconnect the speaker wires from the motherboard.
    • When reconnecting the battery and speakers to the new motherboard, be careful to make the connections to the correct nodes as well as establish a complete connection, as the speakers could break with an incorrect connection and the battery risks overheating or erupting in flames if corrected incorrectly or poorly.
    FixBot'a Sor
    Yorum Ekle
  5. OontZ Angle 3 Motherboard Replacement: adım 5, 3 resimden 1. OontZ Angle 3 Motherboard Replacement: adım 5, 3 resimden 2. OontZ Angle 3 Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the three (3) 3.6mm screws using a Phillips #0 screwdriver.
    • Use the plastic opening tool about midway down one side of the motherboard to pry it out of the casing.
    • Remove the faulty motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Mason Hollander
1.604 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G6
4 Üyeler
15Kılavuz Yorumları
where do i buy mother board of oontz angle 3?
Jomar Agcaoili - Yanıt Paylaş
how much does a new motherboard cost??
Linda Coppola - Yanıt Paylaş
Can you post where to get a new MB?
Brian Dickert - Yanıt Paylaş
It does require a part...the new motherboard!
I'm having a hard time tracking down motherboards too. But the guide is still helpful if someone wants to harvest a motherboard out of another broken Oontz and use it in their own. If anyone else finds a source for the motherboard, feel free to edit the guide and include a link to it in the details section. Maybe if we all work together we can find a source.
Kelsea Weber - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 64
Her zaman: 13,902
