Ana içeriğe geç
OontZ Angle 3 Speaker Replacement
Neye ihtiyacın var
  1. OontZ Angle 3 Speaker Replacement, Back Case: adım 1, 3 resimden 1. OontZ Angle 3 Speaker Replacement, Back Case: adım 1, 3 resimden 2. OontZ Angle 3 Speaker Replacement, Back Case: adım 1, 3 resimden 3.
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Speaker Replacement: adım 2, 1 resimden 1.
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Speaker Replacement: adım 3, 2 resimden 1. OontZ Angle 3 Speaker Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Speaker Replacement, Speaker: adım 4, 2 resimden 1. OontZ Angle 3 Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Use the plastic opening tool to remove the front speaker plate from the speaker.
  5. OontZ Angle 3 Speaker Replacement: adım 5, 2 resimden 1. OontZ Angle 3 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the eight (8) 5.25mm screws with the Phillips #0 screwdriver.
    • Open access to the speakers by letting them rest as shown.
  6. OontZ Angle 3 Speaker Replacement: adım 6, 2 resimden 1. OontZ Angle 3 Speaker Replacement: adım 6, 2 resimden 2.
    • Use the soldering iron to carefully disconnect the speaker(s) from the motherboard connection wires.
    • Learn more about soldering here.
    • Remove the disconnected speaker(s).
    • When reconnecting the wires to the new speaker(s), be careful to connect the wires to the correct nodes (red for positive and black for negative). If they are reconnected to the wrong locations the speakers will either not work or break.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Mason Hollander
1.387 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S15G6
4 Üyeler
7 Yorum
Where do you buy replacement speakers?
michalfiona - Yanıt
Where do you buy the replacement speakers?
What type to buy?
michalfiona - Yanıt
where i buy the speaker replacement/
Sharina Uadan - Yanıt
Where can i buy the replacement speakers
Anil Meda - Yanıt
same question, I am looking for original speaker for oontz angle 3 and I can’t find one. Those who are looking for the size, its 40x40mm (1.57”) 4ohms 3W
Dwayne Champ Manuel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 82
Her zaman: 8,084
