Ana içeriğe geç
Oontz Angle 3 ULTRA Driver Replacement
Neye ihtiyacın var
  1. Oontz Angle 3 ULTRA Driver Replacement, Back Panel: adım 1, 3 resimden 1. Oontz Angle 3 ULTRA Driver Replacement, Back Panel: adım 1, 3 resimden 2. Oontz Angle 3 ULTRA Driver Replacement, Back Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Driver Replacement: adım 2, 3 resimden 1. Oontz Angle 3 ULTRA Driver Replacement: adım 2, 3 resimden 2. Oontz Angle 3 ULTRA Driver Replacement: adım 2, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Driver Replacement: adım 3, 3 resimden 1. Oontz Angle 3 ULTRA Driver Replacement: adım 3, 3 resimden 2. Oontz Angle 3 ULTRA Driver Replacement: adım 3, 3 resimden 3.
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Driver Replacement: adım 4, 3 resimden 1. Oontz Angle 3 ULTRA Driver Replacement: adım 4, 3 resimden 2. Oontz Angle 3 ULTRA Driver Replacement: adım 4, 3 resimden 3.
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA Driver Replacement, Driver: adım 5, 1 resimden 1.
    • Insert the Jimmy into the gap between the speaker's grill and the plastic enclosure.
    • Work the Jimmy around the gap to free it from the speaker enclosure.
    • The grill edges are sharp. Be careful and patient when performing this step to avoid injuring yourself.
  6. Oontz Angle 3 ULTRA Driver Replacement: adım 6, 1 resimden 1.
    Desoldering Pump
    $3.99
    • Locate the wires connecting to the driver. There will be a red wire connected to the driver’s positive terminal, and a black wire connected to the driver’s negative terminal.
    • During reassembly, it is important to orient the wires properly to avoid damage to the speaker and new drivers.
    • With your soldering iron and solder sucker, remove the solder connecting the wires to each terminal, and then gently pull the wires away from the terminals to free them.
    • For more information on soldering and desoldering connections, please read the How to Solder and Desolder Connections Guide.
  7. Oontz Angle 3 ULTRA Driver Replacement: adım 7, 2 resimden 1. Oontz Angle 3 ULTRA Driver Replacement: adım 7, 2 resimden 2.
    • Remove the eight screws with the Phillips #0 screwdriver.
    • Gently push the driver from the rear out of the enclosure to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Where can i purchase replacement speaker
John Benedict Sumallo - Yanıt
reference of speakers of Oontz Angle 3 ULTRA U12A pls to replacement speaker
Luis Calderon - Yanıt
any luck on replacement speakers?
Tirso Ramirez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 31
Her zaman: 1,105
