Ana içeriğe geç
Oontz Angle 3 ULTRA Motherboard Replacement
Neye ihtiyacın var
  1. Oontz Angle 3 ULTRA Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Oontz Angle 3 ULTRA Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Oontz Angle 3 ULTRA Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA Motherboard Replacement: adım 2, 3 resimden 1. Oontz Angle 3 ULTRA Motherboard Replacement: adım 2, 3 resimden 2. Oontz Angle 3 ULTRA Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA Motherboard Replacement: adım 3, 3 resimden 1. Oontz Angle 3 ULTRA Motherboard Replacement: adım 3, 3 resimden 2. Oontz Angle 3 ULTRA Motherboard Replacement: adım 3, 3 resimden 3.
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA Motherboard Replacement: adım 4, 3 resimden 1. Oontz Angle 3 ULTRA Motherboard Replacement: adım 4, 3 resimden 2. Oontz Angle 3 ULTRA Motherboard Replacement: adım 4, 3 resimden 3.
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Using the spudger, remove the motherboard from the device.
    • Be cautious not to break the USB and 3.5mm auxiliary ports which are poking through the side of the device.
    • The microphone wires that connect to the back of the motherboard are very thin and may pull out. Do not worry, the following step is removing those wires.
  6. Oontz Angle 3 ULTRA Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a soldering iron, remove microphone wires attached to the motherboard.
    • Melt the solder on the battery terminals on the motherboard and pull the wires through the backside of the board.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  7. Oontz Angle 3 ULTRA Motherboard Replacement: adım 7, 2 resimden 1. Oontz Angle 3 ULTRA Motherboard Replacement: adım 7, 2 resimden 2.
    • Using a spudger, disconnect the speaker bus female connector from the motherboard's male bus.
    • Remove the grounding wire from the back of the motherboard by gently pulling the metal connection directly away from the board.
  8. Oontz Angle 3 ULTRA Motherboard Replacement: adım 8, 1 resimden 1.
    • With the new motherboard, re-solder all of the wiring into their appropriate soldering locations and wiring harnesses.
    • Reassemble the speaker in reverse order.
Sonuç
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Greetings.
Where can I find boards for my Angle 3 Ultra ??
Chris JOSEPH - Yanıt
can we have the parts of mother board so we as a beginner in electricians need this
Von Gerald Briones - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 903
