Ana içeriğe geç
Opening Procedure
Neye ihtiyacın var
  1. Opening Procedure, Power down your watch: adım 1, 2 resimden 1. Opening Procedure, Power down your watch: adım 1, 2 resimden 2.
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    FixBot'a Sor
    Yorum Ekle
  2. Opening Procedure, Unfasten the back cover: adım 2, 1 resimden 1.
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Opening Procedure, Loosen the back cover adhesive: adım 3, 1 resimden 1.
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    FixBot'a Sor
    Yorum Ekle
  4. Opening Procedure, Pry up the back cover assembly: adım 4, 3 resimden 1. Opening Procedure, Pry up the back cover assembly: adım 4, 3 resimden 2. Opening Procedure, Pry up the back cover assembly: adım 4, 3 resimden 3.
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    FixBot'a Sor
    Yorum Ekle
  5. Opening Procedure, Disconnect the sensor assembly cable: adım 5, 2 resimden 1. Opening Procedure, Disconnect the sensor assembly cable: adım 5, 2 resimden 2.
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    FixBot'a Sor
    Yorum Ekle
  6. Opening Procedure, Remove the back cover assembly: adım 6, 3 resimden 1. Opening Procedure, Remove the back cover assembly: adım 6, 3 resimden 2. Opening Procedure, Remove the back cover assembly: adım 6, 3 resimden 3.
    • Remove the back cover assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
260.167 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.591 adet Kılavuz yazıldı
2Kılavuz Yorumları
Whelp. I got it open thanks to this guide, but there's nothing I can see that would fix my main/power button not being responsive (thus the watch won't turn on anymore). Thanks anyway!
Hailey R - Yanıt Paylaş
Heb de batterij van mijn Ticwatch Pro 3 ultra succesvol kunnen vervangen. Ik zou enkel de specialized watch adhesive tape nog moeten hebben voor deze horloge om hem terug waterproof te hebben?
Patrick Vercammen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 75
Her zaman: 2,370
