Ana içeriğe geç
Oral-B White Pro 1000 Motherboard Replacement
Neye ihtiyacın var
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: adım 2, 3 resimden 1. Oral-B White Pro 1000 Motherboard Replacement: adım 2, 3 resimden 2. Oral-B White Pro 1000 Motherboard Replacement: adım 2, 3 resimden 3.
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Motherboard Replacement: adım 3, 2 resimden 1. Oral-B White Pro 1000 Motherboard Replacement: adım 3, 2 resimden 2.
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Motherboard Replacement: adım 4, 2 resimden 1. Oral-B White Pro 1000 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Motherboard Replacement: adım 5, 3 resimden 1. Oral-B White Pro 1000 Motherboard Replacement: adım 5, 3 resimden 2. Oral-B White Pro 1000 Motherboard Replacement: adım 5, 3 resimden 3.
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Motherboard Replacement: adım 6, 2 resimden 1. Oral-B White Pro 1000 Motherboard Replacement: adım 6, 2 resimden 2.
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Motherboard Replacement: adım 7, 2 resimden 1. Oral-B White Pro 1000 Motherboard Replacement: adım 7, 2 resimden 2.
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
Sonuç
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
2 farklı kişi bu kılavuzu tamamladı.
Hannah Parker
206 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S5-G4, Baechle Fall 2017 IUPUI, Team S5-G4, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S5G4
3 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Motor are brushless?
joseferreira_ms - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 55
Her zaman: 2,753
