Ana içeriğe geç
Orbo Jr. Camera Replacement
Neye ihtiyacın var
    1. Orbo Jr. Camera Replacement, Battery: adım 1, 1 resimden 1.
      • Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
      FixBot'a Sor
      Yorum Ekle
    2. Orbo Jr. Camera Replacement: adım 2, 3 resimden 1. Orbo Jr. Camera Replacement: adım 2, 3 resimden 2. Orbo Jr. Camera Replacement: adım 2, 3 resimden 3.
      • Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
      • Go slowly when you pry the back off to ensure you do not crack the case or damage the screen.
      FixBot'a Sor
      Yorum Ekle
    3. Orbo Jr. Camera Replacement: adım 3, 1 resimden 1.
      • Gently pull the cables attached to the speaker to remove it from the back cover.
      • The speaker is taped in the back cover and caution should be used when pulling on the wires.
      FixBot'a Sor
      Yorum Ekle
    4. Orbo Jr. Camera Replacement: adım 4, 1 resimden 1.
      • Pull back the tape to expose the wires that are attached to the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Orbo Jr. Camera Replacement: adım 5, 2 resimden 1. Orbo Jr. Camera Replacement: adım 5, 2 resimden 2.
      • Do not attempt to fully remove the battery. It is still connected to the motherboard by two wires.
      • Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
      • To avoid damage to device and battery, do not attempt to remove the battery until adhesive is completely detached.
      FixBot'a Sor
      Yorum Ekle
    6. Orbo Jr. Camera Replacement: adım 6, 3 resimden 1. Orbo Jr. Camera Replacement: adım 6, 3 resimden 2. Orbo Jr. Camera Replacement: adım 6, 3 resimden 3.
      • Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
      • Positive and Negative battery terminals.
      • Be careful to not make contact to other components on the motherboard while using the soldering iron.
      FixBot'a Sor
      Yorum Ekle
    1. Orbo Jr. Camera Replacement, Camera: adım 7, 3 resimden 1. Orbo Jr. Camera Replacement, Camera: adım 7, 3 resimden 2. Orbo Jr. Camera Replacement, Camera: adım 7, 3 resimden 3.
      • Use the pointed end of a spudger to flip up the black tab connecting the camera's ribbon cable to the motherboard.
      • Camera ribbon clip.
      • Pull lightly on the ribbon to remove the camera ribbon from the tab.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Ryan Christman
684 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Sullivan Spring 2016 USF Tampa, Team 3-1, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G1
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 636
