Neye ihtiyacın var
Unscrew the 16mm screws located on the plastic bottom from the blender base using a Phillips #2 screwdriver.
Is it possible to get a replacement base. Just the plastic cover? I can't seem to find mine and it is cracked and broken yet still works.
Now de-solder the yellow wire from circuit board. De-solder the wire following these instructions.
Now the fan and motor are ready for replacement. To reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
My blender would not blend smoothly. It use to make an unusually loud noise when I put the cup and start the motor. I realized the motor had a "play" making me believe it was not tightened enough. I took a look at the pics on this page and then realized it was assembled wrongly. The white rubber used to absorb the movement was placed after the motor was inserted. Thanks to all who have contributed to this Oster page.
Good day
i took apart my whole oster blender took the electric board out and all the button pieces came out. I have no idea what order they go in or how to put it back. There was a small spring that fell out as well as a Small plastic piece with 2 small springs in it. Can u please help?
