Ana içeriğe geç
Oster 6329 Circuit Board Resistor Replacement
Neye ihtiyacın var
  1. Oster 6329 Circuit Board Resistor Replacement, Outer Shell Removal: adım 1, 2 resimden 1. Oster 6329 Circuit Board Resistor Replacement, Outer Shell Removal: adım 1, 2 resimden 2.
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Circuit Board Resistor Replacement: adım 2, 1 resimden 1.
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
    It really helped me to use a heat gun to warm up the handle a tiny bit.
    KC Embrey - Yanıt
  3. Oster 6329 Circuit Board Resistor Replacement: adım 3, 1 resimden 1.
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Circuit Board Resistor Replacement: adım 4, 2 resimden 1. Oster 6329 Circuit Board Resistor Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Circuit Board Resistor Replacement: adım 5, 2 resimden 1. Oster 6329 Circuit Board Resistor Replacement: adım 5, 2 resimden 2.
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
  6. Oster 6329 Circuit Board Resistor Replacement, Circuit Board Resistor: adım 6, 1 resimden 1.
    • Using a #1 phillips head screwdriver, remove the four 1cm philips head screws holding the circuit board to the inside of the toaster shell.
  7. Oster 6329 Circuit Board Resistor Replacement: adım 7, 1 resimden 1.
    • Grasp the circuit board and pull on it perpendicular to the attached surface.
  8. Oster 6329 Circuit Board Resistor Replacement: adım 8, 1 resimden 1.
    • Inspect the circuit board for any burnt or otherwise damaged components. Be sure to carefully identify the damaged components that need replacement. For help identifying resistor values look at wikipedia's electronic color code article.
  9. Oster 6329 Circuit Board Resistor Replacement: adım 9, 1 resimden 1.
    • Use the soldering kit to unsolder the damaged component. For soldering Instructions look at the iFixit Soldering Guide.
  10. Oster 6329 Circuit Board Resistor Replacement: adım 10, 1 resimden 1.
    • Once the damaged component has been unsoldered from the circuit board, remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Timothy Grijalva
234 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G15
5 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where are replacement parts for a toaster available typically?
Bruce odom - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 2,131
