Ana içeriğe geç
Overclocking your eMac
Emmanouil Georgopoulos
Emmanouil Georgopoulos ve 2 diğer katkıda bulunanlar
En son May 11, 2023 tarihinde güncellendi
1 saat
Çok zor
Topluluk-Katkılı Kılavuz
Hodri Meydan: Tamir Et
Back in 2003 when i was still studying, i bought an used eMac G4 with a 800 MHz processor. After some time with the help of my closest friends Claudio Nizzoli and Vassilis Moutsos we decided to operate on my eMac and we managed to speed it up to 1.33 GHz after 4 years in late '07s together.
Still now days i recall the goosebumps and chills watching my friends trying to scratch of some resistors from the board as i was holding it to achieve the overclock as my eMac costed me 6 months of salary when i was working and studying. It was not a good idea to play with but we surly enjoyed it.
This guide was made in memory of those moments and for all those who still own one and would love to juice out some power of it and it is based on featured guides from iFixit members Arthur Shi, Chris Green and an outsider Leo Bodnar who gave me the idea.
Hope you enjoy it as i did those days. Please feel free to contact me for details or featured corrections.
  1. Overclocking your eMac, Door Removal: adım 1, 3 resimden 1. Overclocking your eMac, Door Removal: adım 1, 3 resimden 2. Overclocking your eMac, Door Removal: adım 1, 3 resimden 3.
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
    carpet or towel is the way to go. don’t put on bare hardwood floor or table as you may scratch it
    Duck - Yanıt
  2. Overclocking your eMac, Bottom Screw Removal: adım 2, 1 resimden 1.
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. Overclocking your eMac, Top and Side Screws: adım 3, 3 resimden 1. Overclocking your eMac, Top and Side Screws: adım 3, 3 resimden 2. Overclocking your eMac, Top and Side Screws: adım 3, 3 resimden 3.
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. Overclocking your eMac, Power Button Cable: adım 4, 2 resimden 1. Overclocking your eMac, Power Button Cable: adım 4, 2 resimden 2.
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
    What happens if you pull the shell off before does couldn’t connecting the power button and completely rip the wires right out of the quick connect,, well that’s exactly what I did and I need to know how to fix it please thank you
    Kolby Hughston - Yanıt
  5. Overclocking your eMac, Shell Removal: adım 5, 1 resimden 1.
    • Now the entire shell can be removed from the computer.
  6. Overclocking your eMac, Panel Removal: adım 6, 3 resimden 1. Overclocking your eMac, Panel Removal: adım 6, 3 resimden 2. Overclocking your eMac, Panel Removal: adım 6, 3 resimden 3.
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
  7. Overclocking your eMac, Cables: adım 7, 3 resimden 1. Overclocking your eMac, Cables: adım 7, 3 resimden 2. Overclocking your eMac, Cables: adım 7, 3 resimden 3.
    • To remove the fan assembly, several cables must be disconnected first:
    • 3-pin fan cable
    • Ground wire, requires phillips #2 screwdriver
    • 2-pin AC cable to power supply
  8. Overclocking your eMac, Screws: adım 8, 2 resimden 1. Overclocking your eMac, Screws: adım 8, 2 resimden 2.
    • Now remove the following screws securing the fan assembly:
    • 3x coarse thread phillips #2
    • 1x machine thread phillips #2
  9. Overclocking your eMac: adım 9, 1 resimden 1.
    • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
  10. Overclocking your eMac, Assembly Removal: adım 10, 2 resimden 1. Overclocking your eMac, Assembly Removal: adım 10, 2 resimden 2.
    • You should now be able to remove the fan assembly.
    • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
  11. Overclocking your eMac, Bottom Connectors: adım 11, 1 resimden 1.
    • There are four connectors at the bottom of the motherboard that must be removed.
  12. Overclocking your eMac, Display Connector: adım 12, 3 resimden 1. Overclocking your eMac, Display Connector: adım 12, 3 resimden 2. Overclocking your eMac, Display Connector: adım 12, 3 resimden 3.
    • There is a large display connector that must be removed. This can be done by squeezing the tabs and pulling.
  13. Overclocking your eMac, Power Button Cable: adım 13, 1 resimden 1.
    • The power button cable may be tucked in the casing, you will need to un-tuck it.
  14. Overclocking your eMac, Screws: adım 14, 3 resimden 1. Overclocking your eMac, Screws: adım 14, 3 resimden 2. Overclocking your eMac, Screws: adım 14, 3 resimden 3.
    • There are several phillips #2 screws that hold the eMac motherboard assembly to the rest of the computer. They will all need to be removed.
    • 2 large ones near the drive bay door.
    • 7 smaller ones scattered around
  15. Overclocking your eMac, Screws (Continued): adım 15, 2 resimden 1. Overclocking your eMac, Screws (Continued): adım 15, 2 resimden 2.
    • More of the screw locations from the previous step
  16. Overclocking your eMac, Motherboard Assembly: adım 16, 1 resimden 1.
    • The motherboard assembly should now come free.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
i am searching a POWER BUTTON for my old eMac(2004)
somebody can help me?
my email:cabanel.robert@orange.fr
thank you!
capitaine NEMO - Yanıt
Where is Overclocking ?)
Pavel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 64
Her zaman: 1,926
