Ana içeriğe geç
PDP Afterglow Fener Battery Replacement
Neye ihtiyacın var
  1. PDP Afterglow Fener Battery Replacement, Battery: adım 1, 2 resimden 1. PDP Afterglow Fener Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    Purchased the battery…plug doesn't fit and battery is too big to fit in the headset
    josey thompson - Yanıt
  2. PDP Afterglow Fener Battery Replacement: adım 2, 2 resimden 1. PDP Afterglow Fener Battery Replacement: adım 2, 2 resimden 2.
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Murat Terzi
215 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 üyesi
UMASSD-GULBRANDSEN-F15S5G3
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 7,552
