Ana içeriğe geç
PDP Rematch Top Left and Right Button(s) Replacement
Neye ihtiyacın var
  1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: adım 1, 2 resimden 1. PDP Rematch Top Left and Right Button(s) Replacement, Faceplate: adım 1, 2 resimden 2.
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Top Left and Right Button(s) Replacement: adım 2, 2 resimden 1. PDP Rematch Top Left and Right Button(s) Replacement: adım 2, 2 resimden 2.
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Top Left and Right Button(s) Replacement: adım 3, 2 resimden 1. PDP Rematch Top Left and Right Button(s) Replacement: adım 3, 2 resimden 2.
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: adım 4, 2 resimden 1. PDP Rematch Top Left and Right Button(s) Replacement, Top Left and Right Buttons: adım 4, 2 resimden 2.
    • Remove the back panel by pulling it away from the front.
    • Disconnect the cable by squeezing the two sides while pulling the cable away from the motherboard.
  5. PDP Rematch Top Left and Right Button(s) Replacement: adım 5, 2 resimden 1. PDP Rematch Top Left and Right Button(s) Replacement: adım 5, 2 resimden 2.
    • Touch the hot tip of the soldering iron to the first solder connecting the buttons to the motherboard until the solder melts.
    • Repeat this for the next solder. Verify solders have detached from motherboard.
    • Be careful of the hot soldering tip.
  6. PDP Rematch Top Left and Right Button(s) Replacement: adım 6, 2 resimden 1. PDP Rematch Top Left and Right Button(s) Replacement: adım 6, 2 resimden 2.
    • When the solder has completely melted, flip the controller and gently pull the wire free from the motherboard.
    • Repeat for the other black wire.
Sonuç
GraceGrubbs
147 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 288
