Ana içeriğe geç
PSP 300x Analog Stick Replacement
mbnewsom
mbnewsom ve 13 diğer katkıda bulunanlar
En son March 24, 2025 tarihinde güncellendi
15 dakika
Orta
Tutarsız Görseller
Guide for removing the Analog stick in a Sony PSP-3000
Neye ihtiyacın var
Parçalar
Aletler
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Daha fazlasını göster…
  1. PSP 300x Analog Stick Replacement, Battery: adım 1, 3 resimden 1. PSP 300x Analog Stick Replacement, Battery: adım 1, 3 resimden 2. PSP 300x Analog Stick Replacement, Battery: adım 1, 3 resimden 3.
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Analog Stick Replacement, Front Casing: adım 2, 1 resimden 1.
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Yanıt
    Even though warranties are long expired on these things.
    Vincent C. -
    “IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
    Barry Goian - Yanıt
  3. PSP 300x Analog Stick Replacement: adım 3, 2 resimden 1. PSP 300x Analog Stick Replacement: adım 3, 2 resimden 2.
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Analog Stick Replacement: adım 4, 1 resimden 1.
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Analog Stick Replacement: adım 5, 1 resimden 1.
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    “DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
    Barry Goian - Yanıt
  6. PSP 300x Analog Stick Replacement: adım 6, 2 resimden 1. PSP 300x Analog Stick Replacement: adım 6, 2 resimden 2.
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
    Valentin Boileau - Yanıt
  7. PSP 300x Analog Stick Replacement, LCD Screen: adım 7, 2 resimden 1. PSP 300x Analog Stick Replacement, LCD Screen: adım 7, 2 resimden 2.
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    The homebar has a little tab screwed in place under the screw that alsoholds the lanyard trim-piece on. You will need to unscrew that screw first and pry the lanyard piece up, to get the homebar out from under it.
    B McG - Yanıt
  8. PSP 300x Analog Stick Replacement: adım 8, 3 resimden 1. PSP 300x Analog Stick Replacement: adım 8, 3 resimden 2. PSP 300x Analog Stick Replacement: adım 8, 3 resimden 3.
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Attention à cette partie où l’écran est un peu bloqué dans le coin inférieur droit, il faut donner un peu de jeu vers la gauche pour le décaler et le retirer plus facilement.
  9. PSP 300x Analog Stick Replacement: adım 9, 2 resimden 1. PSP 300x Analog Stick Replacement: adım 9, 2 resimden 2.
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    For anyone struggling to get the screen’s smaller ribbon cable back in, don’t be too afraid to use tweezers to pull on the little tabs. It has to go in a good half way (of the darker area) in order for you to latch it without it falling back out.
    Tom - Yanıt
  10. PSP 300x Analog Stick Replacement: adım 10, 1 resimden 1.
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. PSP 300x Analog Stick Replacement, Trigger Buttons: adım 11, 1 resimden 1.
    • Remove the screw securing 'L' trigger to the PSP.
  12. PSP 300x Analog Stick Replacement: adım 12, 1 resimden 1.
    • Remove the white plastic piece that holds the 'L' trigger in place.
  13. PSP 300x Analog Stick Replacement: adım 13, 1 resimden 1.
    • Remove the 'L' trigger from the PSP.
  14. PSP 300x Analog Stick Replacement: adım 14, 1 resimden 1.
    • Remove the screw securing the 'R' trigger.
  15. PSP 300x Analog Stick Replacement: adım 15, 1 resimden 1.
    • Remove the white plastic piece that holds the 'R' trigger in place.
  16. PSP 300x Analog Stick Replacement: adım 16, 1 resimden 1.
    • Remove the 'R' trigger from the PSP.
  17. PSP 300x Analog Stick Replacement, Analog Stick: adım 17, 1 resimden 1.
    • Remove the screw from the bottom left edge of the PSP.
  18. PSP 300x Analog Stick Replacement: adım 18, 1 resimden 1.
    • Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
    Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the 'L' trigger off the PSP.
    buzinon - Yanıt
  19. PSP 300x Analog Stick Replacement: adım 19, 2 resimden 1. PSP 300x Analog Stick Replacement: adım 19, 2 resimden 2.
    • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
    Be careful - the memory card should be taken out by now. If not, the d-pad assembly will not come out. You can safely remove it if you forgot though.
    Kris - Yanıt
  20. PSP 300x Analog Stick Replacement: adım 20, 1 resimden 1.
    • Remove the cable from the connector and remove the entire black piece from the PSP.
  21. PSP 300x Analog Stick Replacement: adım 21, 1 resimden 1.
    • Remove the screw holding the analog stick in place.
  22. PSP 300x Analog Stick Replacement: adım 22, 2 resimden 1. PSP 300x Analog Stick Replacement: adım 22, 2 resimden 2.
    • Flip up the lock on the analog sticks ribbon cable.
    • Remove the analog stick from the PSP.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
mbnewsom
3.316 İtibar
11 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you for the tutorial, and I learned a lot!
Charda Eben Haezer - Yanıt
Thank you so much!!! you are the best!!!
Hisler Sadeck - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 116
Son 30 gün: 558
Her zaman: 41,767
