PSP Go Display Replacement
Giriş
1. adıma gitUse this guide if you cracked your PSP Go's display!
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use a plastic opening tool to gently flip up the left trigger connector.
Use the plastic opening tool to gently peel away at the "Warranty Void" sticker. Start on one edge, as shown, and slide the tool from side to side until the sticker is removed from just the battery.
Gently pull the sticker away from the battery connector, just enough so that the connector is visible.
Wedge a plastic opening tool in between the connector and logic board, and gently pull the connector upwards.
If you are having trouble charging up your system. Try reseating the battery connector of this step before purchasing a new battery. This is a common problem with PSP go systems that haven't been used for a while. If the battery still doesn't charge after reseating the connector, you might need a new battery.
Remove the single Phillips screw securing the logic board to the inner case.
Wedge a plastic opening tool between the plastic front panel and display. Be very careful that you wedge it in the same location shown in the first picture.
Slide the plastic opening tool across the length of the display. This should loosen the glue binding the display to the plastic front panel.
Rotate the display 180 degrees and free the bottom side of the display in the same manner.
27 farklı kişi bu kılavuzu tamamladı.
5 Yorum
Omg seriously!,,, Took this Dental Hygienist exactly one hour to do this! Awesome ! Thank you!
My psp won't turn back on please help I followed the directions exactly.
I use this guides to perform a flexible replacement because the original one is just too old and it's snapped some how, I've done it and my PSP Go work normal as before but I did make a mistake. I cracked the display. Yes it is really, really, really fragile! When he said “be very gentle/careful” he really mean it.
Learn from my mistakes, but I will fix it. Again.
