Palm Pre Keypad Control Board Replacement
Neye ihtiyacın var
Make sure your Palm Pre is turned off before disassembling the phone.
Snap off the back panel to reveal the battery.
Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
Bu adımda kullanılan alet:Tweezers$4.99
Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
Use a spudger to pry open the hinge.
Use tweezers to disconnect the antennas from the keypad control board.
Remove the two ribbon cable connectors using tweezers.
