Ana içeriğe geç
Palm TX Battery Pack Replacement
Neye ihtiyacın var
  1. Palm TX Battery Pack Replacement, Back Panel: adım 1, 2 resimden 1. Palm TX Battery Pack Replacement, Back Panel: adım 1, 2 resimden 2.
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
    FixBot'a Sor
    Yorum Ekle
  2. Palm TX Battery Pack Replacement: adım 2, 1 resimden 1.
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
    FixBot'a Sor
    Yorum Ekle
  3. Palm TX Battery Pack Replacement: adım 3, 2 resimden 1. Palm TX Battery Pack Replacement: adım 3, 2 resimden 2.
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
    FixBot'a Sor
    Yorum Ekle
  4. Palm TX Battery Pack Replacement: adım 4, 2 resimden 1. Palm TX Battery Pack Replacement: adım 4, 2 resimden 2.
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
    FixBot'a Sor
    Yorum Ekle
  5. Palm TX Battery Pack Replacement: adım 5, 2 resimden 1. Palm TX Battery Pack Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
    FixBot'a Sor
    Yorum Ekle
  6. Palm TX Battery Pack Replacement, Battery Pack: adım 6, 2 resimden 1. Palm TX Battery Pack Replacement, Battery Pack: adım 6, 2 resimden 2.
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Spencer Lewson
793 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G15
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
In step 1 - Also remove the cover hinge by sliding downwards
In step 3 - there are actually 2 crevices on the left side of the device. Use the larger, which originally held the cover hinge (the smaller crevice seems to remove the facia)
Jack - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 63
Her zaman: 8,519
