Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Turn over the device so that the back panel faces forward.
Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
Rotate the device so that the display faces forward.
Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
Pry along the crevice to loosen the back panel.
Repeat this process for the right side.
Use a plastic opening tool to peel the battery pack from the back panel.
Use a soldering iron to disconnect the battery wires from the motherboard.
For soldering instructions, you can view the Soldering Guide.
5 farklı kişi bu kılavuzu tamamladı.
