Ana içeriğe geç
Palm TX Buttons and Connector Assembly Replacement
Neye ihtiyacın var
  1. Palm TX Buttons and Connector Assembly Replacement, Back Panel: adım 1, 2 resimden 1. Palm TX Buttons and Connector Assembly Replacement, Back Panel: adım 1, 2 resimden 2.
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
    FixBot'a Sor
    Yorum Ekle
  2. Palm TX Buttons and Connector Assembly Replacement: adım 2, 1 resimden 1.
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
    FixBot'a Sor
    Yorum Ekle
  3. Palm TX Buttons and Connector Assembly Replacement: adım 3, 2 resimden 1. Palm TX Buttons and Connector Assembly Replacement: adım 3, 2 resimden 2.
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
    FixBot'a Sor
    Yorum Ekle
  4. Palm TX Buttons and Connector Assembly Replacement: adım 4, 2 resimden 1. Palm TX Buttons and Connector Assembly Replacement: adım 4, 2 resimden 2.
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
    FixBot'a Sor
    Yorum Ekle
  5. Palm TX Buttons and Connector Assembly Replacement: adım 5, 2 resimden 1. Palm TX Buttons and Connector Assembly Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
    FixBot'a Sor
    Yorum Ekle
  6. Palm TX Buttons and Connector Assembly Replacement, Battery Pack: adım 6, 2 resimden 1. Palm TX Buttons and Connector Assembly Replacement, Battery Pack: adım 6, 2 resimden 2.
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
    FixBot'a Sor
    Yorum Ekle
  7. Palm TX Buttons and Connector Assembly Replacement, Motherboard: adım 7, 2 resimden 1. Palm TX Buttons and Connector Assembly Replacement, Motherboard: adım 7, 2 resimden 2.
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
    FixBot'a Sor
    Yorum Ekle
  8. Palm TX Buttons and Connector Assembly Replacement: adım 8, 2 resimden 1. Palm TX Buttons and Connector Assembly Replacement: adım 8, 2 resimden 2.
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
    FixBot'a Sor
    Yorum Ekle
  9. Palm TX Buttons and Connector Assembly Replacement, Display: adım 9, 1 resimden 1.
    • Orient the device sideways, as shown in the picture.
    • Lightly push the front of the display to separate it from the front panel.
    • The battery in the picture will not be attached to the device at this point.
    FixBot'a Sor
    Yorum Ekle
  10. Palm TX Buttons and Connector Assembly Replacement, Buttons and Connector Assembly: adım 10, 1 resimden 1.
    • Use a T5 Torx screwdriver to remove the 7.75mm screws at the bottom of the device.
    • It may take some manipulation to remove the screws.
    FixBot'a Sor
    Yorum Ekle
  11. Palm TX Buttons and Connector Assembly Replacement: adım 11, 1 resimden 1.
    • Lift the button and connector assembly from the front panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Spencer Lewson
793 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G15
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
Where can you buy one of these?
Sean Madawala - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 2,085
