Ana içeriğe geç
Palm Treo 755p Antenna Replacement
Neye ihtiyacın var
  1. Palm Treo 755p Antenna Replacement, Battery: adım 1, 3 resimden 1. Palm Treo 755p Antenna Replacement, Battery: adım 1, 3 resimden 2. Palm Treo 755p Antenna Replacement, Battery: adım 1, 3 resimden 3.
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Antenna Replacement: adım 2, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 2, 2 resimden 2.
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Antenna Replacement, Back Cover: adım 3, 2 resimden 1. Palm Treo 755p Antenna Replacement, Back Cover: adım 3, 2 resimden 2.
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Antenna Replacement: adım 4, 1 resimden 1.
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Antenna Replacement: adım 5, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Antenna Replacement: adım 6, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 6, 2 resimden 2.
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Antenna Replacement: adım 7, 3 resimden 1. Palm Treo 755p Antenna Replacement: adım 7, 3 resimden 2. Palm Treo 755p Antenna Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  8. Palm Treo 755p Antenna Replacement, Antenna: adım 8, 1 resimden 1.
    • The antenna is on the back half of the phone.
  9. Palm Treo 755p Antenna Replacement: adım 9, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 9, 2 resimden 2.
    • Press in the four black clips using a spudger to pop off the upper-back cover.
  10. Palm Treo 755p Antenna Replacement: adım 10, 1 resimden 1.
    • Lift off the top of the back cover from the phone frame.
  11. Palm Treo 755p Antenna Replacement: adım 11, 2 resimden 1. Palm Treo 755p Antenna Replacement: adım 11, 2 resimden 2.
    • Gently pop off the antenna by pulling it away from the back cover.
Sonuç
Mike Shaw
601 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-6, Forte Winter 2011 Cal Poly, Team 14-6, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G6
6 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,754
