Ana içeriğe geç
Panasonic DMC-FZ70 Operation  Unit Replacement
Alberto Rodriguez
Alberto Rodriguez ve 6 diğer katkıda bulunanlar
En son September 18, 2020 tarihinde güncellendi
15 dakika
Orta
The Operations Unit is a panel of top of the camera that contains the mode dial, power switch, shutter button, and video-record button. If any of these buttons are missing, jammed, or no longer working, you can use this guide to learn how to replace the unit. Before you begin, make sure that the battery and SD card have been removed.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. Panasonic DMC-FZ70 Operation  Unit Replacement, Back Panel: adım 1, 2 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement, Back Panel: adım 1, 2 resimden 2.
    • All screws should be removed using a Phillips #0 screwdriver.
    • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
  2. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 2, 2 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 2, 2 resimden 2.
    • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
  3. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 3, 2 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 3, 2 resimden 2.
    • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
  4. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 4, 2 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 4, 2 resimden 2.
    • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
    • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
  5. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 5, 1 resimden 1.
    • Proceed to remove the four 5mm Phillips screws that you just uncovered.
  6. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 6, 1 resimden 1.
    • Slowly pull on both side of the camera, until both halves begin to separate from each other.
    • Do not pull too hard, as both halves are held together with ZIF connector cables.
  7. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 7, 3 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 7, 3 resimden 2. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
    • Carefully pull the ribbon cables out of the slot once they have been released.
    • Only the two indicated connectors need to be removed to separate the two halves of the camera.
  8. Panasonic DMC-FZ70 Operation  Unit Replacement, Motherboard: adım 8, 1 resimden 1.
    • Using a Torx driver, unscrew the two 5mm Phillipd screws on the motherboard
  9. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 9, 3 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 9, 3 resimden 2. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 9, 3 resimden 3.
    • The five ribbon cables shown will need to be removed from the ZIF connectors. Using a plastic opening tool, unlock the cables by lifting the black strip on the rectangular connection socket.
    • Carefully pull each of the ribbon cables out of their sockets.
    • The cable should slide out smoothly- any significant resistance might signal that the locking lever has not yet released the cable.
  10. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 10, 2 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 10, 2 resimden 2.
    • Once the screws and the ribbon cables have been removed, lift the mother board from its slot.
  11. Panasonic DMC-FZ70 Operation  Unit Replacement, Operation  Unit: adım 11, 2 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement, Operation  Unit: adım 11, 2 resimden 2.
    • Unscrew one 10mm Phillips screw to the right and underneath the viewfinder.
  12. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 12, 1 resimden 1.
    • Using a plastic opening tool, flip up the switch on the ZIF connector underneath the operations unit and pull the ribbon out of the motherboard.
  13. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 13, 3 resimden 1. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 13, 3 resimden 2. Panasonic DMC-FZ70 Operation  Unit Replacement: adım 13, 3 resimden 3.
    • Slide out and replace the operation unit.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alberto Rodriguez
531 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-3, Maness Winter 2017 Cal Poly, Team 21-3, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G3
6 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Alberto,
Great instructions! Saved me $165 (compared to camera repair shop).
Professor Roy Hinkley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 2,320
