Ana içeriğe geç
Panasonic KX-TGE233 Power Port Replacement
Neye ihtiyacın var
  1. Panasonic KX-TGE233 Power Port Replacement, Base Front Panel Assembly: adım 1, 1 resimden 1.
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 Power Port Replacement: adım 2, 1 resimden 1.
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 Power Port Replacement: adım 3, 1 resimden 1.
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 Power Port Replacement: adım 4, 1 resimden 1.
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 Power Port Replacement: adım 5, 1 resimden 1.
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 Power Port Replacement, Power Port: adım 6, 1 resimden 1.
    • Now that the device has been opened, the power port can easily be removed from its resting point.
  7. Panasonic KX-TGE233 Power Port Replacement: adım 7, 1 resimden 1.
  8. Panasonic KX-TGE233 Power Port Replacement: adım 8, 1 resimden 1.
    • The faulty power port can now be detached from the device from its contact points. If soldering has been successful, removal should require minimal effort.
Sonuç
Nico Cruz
249 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Baechle Spring 2016 IUPUI, Team 2-2, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S2G2
5 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 2,140
