Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
With the screws removed, you can use a spudger to aid in removing the back from the device.
With the back removed, we now have direct access to all other components in the main docking station.
Now that the device has been opened, the power port can easily be removed from its resting point.
Use a soldering iron to loosen the solder on the contact points.
The faulty power port can now be detached from the device from its contact points. If soldering has been successful, removal should require minimal effort.
