Ana içeriğe geç
Panasonic Lumix DMC-FX07 Memory Card Replacement
Karissa
Karissa ve 4 diğer katkıda bulunanlar
En son January 28, 2014 tarihinde güncellendi
2 - 3 dakika
Kolay
The guide will take you through the steps of how to remove the memory card.
  1. Panasonic Lumix DMC-FX07 Memory Card Replacement, Battery: adım 1, 1 resimden 1.
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Memory Card Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-FX07 Memory Card Replacement: adım 2, 2 resimden 2.
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Memory Card Replacement, Memory Card: adım 3, 1 resimden 1.
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
Sonuç
Karissa
50 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-23, Amido Spring 2012 Cal Poly, Team 6-23, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S6G23
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 969
