Ana içeriğe geç
Panasonic Lumix DMC-ZS60 Camera Lens Replacement
Neye ihtiyacın var
  1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Battery: adım 1, 1 resimden 1.
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 2, 2 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 2, 2 resimden 2.
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 3, 1 resimden 1.
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: adım 4, 3 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: adım 4, 3 resimden 2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: adım 4, 3 resimden 3.
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 5, 1 resimden 1.
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 6, 2 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 7, 3 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 7, 3 resimden 2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 7, 3 resimden 3.
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 8, 2 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 8, 2 resimden 2.
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 10, 3 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 10, 3 resimden 2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 10, 3 resimden 3.
    Satın Al
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 11, 2 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 11, 2 resimden 2.
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  12. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: adım 12, 2 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: adım 12, 2 resimden 2.
    • Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
    • Pull off the plate cover to uncover the camera lens.
  13. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 13, 2 resimden 1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: adım 13, 2 resimden 2.
    • Lift the camera lens from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
A few years ago, I had a 30x zoom like this. It got a spot of dust inside the lens that showed up in photos, especially zoomed-in. I tried to unscrew the front of the lens to clean out the dust but the plastic broke, ruining the camera.
Fred Oswald - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 2,397
