Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Orient the laptop on its side so that the plastic battery cover is facing upward.
Push down on the battery cover and remove it by sliding the cover down. This may take some force, but the cover should pop up with a soft click.
Use the battery release slider to release the battery latch.
Use the blue tab to pull the battery out of the battery compartment. Make sure to keep the battery latch tab depressed while doing so.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I replaced the battery compatible one and replace the power adapter as well but still shows no power. What other issues may cause no power?
