Ana içeriğe geç
Parrot Skycontroller 2 Power Port Replacement
Neye ihtiyacın var
  1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: adım 1, 3 resimden 1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: adım 1, 3 resimden 2. Parrot Skycontroller 2 Power Port  Replacement, Power Port: adım 1, 3 resimden 3.
    • Flip the controller upside down.
  2. Parrot Skycontroller 2 Power Port  Replacement: adım 2, 1 resimden 1.
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Power Port  Replacement: adım 3, 3 resimden 1. Parrot Skycontroller 2 Power Port  Replacement: adım 3, 3 resimden 2. Parrot Skycontroller 2 Power Port  Replacement: adım 3, 3 resimden 3.
    • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Power Port  Replacement: adım 4, 3 resimden 1. Parrot Skycontroller 2 Power Port  Replacement: adım 4, 3 resimden 2. Parrot Skycontroller 2 Power Port  Replacement: adım 4, 3 resimden 3.
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling apart.
  5. Parrot Skycontroller 2 Power Port  Replacement: adım 5, 2 resimden 1. Parrot Skycontroller 2 Power Port  Replacement: adım 5, 2 resimden 2.
    • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
    • Some force may be required to separate the battery from it's brackets.
  6. Parrot Skycontroller 2 Power Port  Replacement: adım 6, 1 resimden 1.
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
  7. Parrot Skycontroller 2 Power Port  Replacement: adım 7, 3 resimden 1. Parrot Skycontroller 2 Power Port  Replacement: adım 7, 3 resimden 2. Parrot Skycontroller 2 Power Port  Replacement: adım 7, 3 resimden 3.
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Power Port  Replacement: adım 8, 1 resimden 1.
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Power Port  Replacement: adım 9, 1 resimden 1.
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Power Port  Replacement: adım 10, 3 resimden 1. Parrot Skycontroller 2 Power Port  Replacement: adım 10, 3 resimden 2. Parrot Skycontroller 2 Power Port  Replacement: adım 10, 3 resimden 3.
    • Remove the face plate by pulling up and out.
  11. Parrot Skycontroller 2 Power Port  Replacement: adım 11, 3 resimden 1. Parrot Skycontroller 2 Power Port  Replacement: adım 11, 3 resimden 2. Parrot Skycontroller 2 Power Port  Replacement: adım 11, 3 resimden 3.
    • Make sure the controller is flat, then proceed to desolder the power port.
    • Desolder the four connection points surrounding the charging port.
    • Remove the power port from the controller.
    • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
    • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 423
