Ana içeriğe geç
Pentax LX Shutter Speed Resistor Cleaning
Neye ihtiyacın var
  1. Pentax LX Shutter Speed Resistor Cleaning, Remove winding lever: adım 1, 3 resimden 1. Pentax LX Shutter Speed Resistor Cleaning, Remove winding lever: adım 1, 3 resimden 2. Pentax LX Shutter Speed Resistor Cleaning, Remove winding lever: adım 1, 3 resimden 3.
    • Winding lever cover is reverse threaded.
    • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
    • Remove four #000 2.5 mm screws.
    • Use spanners to remove top cover retaining nut.
  2. Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed dial: adım 2, 3 resimden 1. Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed dial: adım 2, 3 resimden 2. Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed dial: adım 2, 3 resimden 3.
    • Gently remove the rubber covering around the shutter speed dial.
    • Remove three #000 1.6 mm screws.
    • Remove cover ring.
    • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
  3. Pentax LX Shutter Speed Resistor Cleaning, Remove wind side top cover: adım 3, 3 resimden 1. Pentax LX Shutter Speed Resistor Cleaning, Remove wind side top cover: adım 3, 3 resimden 2. Pentax LX Shutter Speed Resistor Cleaning, Remove wind side top cover: adım 3, 3 resimden 3.
    • Remove one #00 2.5 mm screw.
    • Remove one #00 X mm screw.
    • Lift off top cover.
  4. Pentax LX Shutter Speed Resistor Cleaning, Remove auto/manual switch: adım 4, 1 resimden 1.
    • Unhook lever spring.
    • Remove one #000 X mm screw.
    • Remove auto/manual switch lever.
    • This contact tells the camera what mode the shutter speed dial is set to: auto, manual (high speed mechanical), manual (low speed electronic), and bulb.
  5. Pentax LX Shutter Speed Resistor Cleaning, Remove timing switch assembly: adım 5, 2 resimden 1. Pentax LX Shutter Speed Resistor Cleaning, Remove timing switch assembly: adım 5, 2 resimden 2.
    • Remove slotted nut. Use isopropyl alcohol to soften thread lock if necessary.
    • Remove all components of the timing switch assembly.
  6. Pentax LX Shutter Speed Resistor Cleaning, Lock viewfinder needle indicator: adım 6, 2 resimden 1. Pentax LX Shutter Speed Resistor Cleaning, Lock viewfinder needle indicator: adım 6, 2 resimden 2.
    • Turn shutter speed selector to 'Auto'.
    • Turn lock lever screw clockwise to loosen. Do not remove.
    • Lock lever screw is reverse threaded.
    • Push lock lever toward the needle indicator gear.
    • Turn lock lever screw counter-clockwise to tighten.
    • Locking the needle indicator keeps it in the proper position once the shutter dial assembly is removed.
  7. Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed selector assembly: adım 7, 2 resimden 1. Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed selector assembly: adım 7, 2 resimden 2.
    • Unsolder two yellow wires.
    • Remove one #00 4.0 mm screw.
    • Remove one #00 2.2 mm screw.
    • Remove high speed cam.
    • Installation Note: Set dial to 'Auto' before installing. After install, unlock the viewfinder indicator and check that it is showing the correct speeds in the viewfinder as the dial is turned.
  8. Pentax LX Shutter Speed Resistor Cleaning, Clean speed resistor: adım 8, 2 resimden 1. Pentax LX Shutter Speed Resistor Cleaning, Clean speed resistor: adım 8, 2 resimden 2.
    • Rotate the speed dial until the feeler contacts are visible in the gap.
    • Spray with a plastic safe contact cleaner and rotate back and forth.
    • Check the resistor values at the slow speed settings. They should range from around 9 kΩ (at 60) to 200 kΩ (at 4s) with no dead spots.
    • Clean the seat for the high speed cam with isopropyl alcohol. A narrow cotton bud or a floss pick work well.
    • Lubricate the high speed cam seat with shutter oil.
Sonuç
Sam Gustafson
7.682 İtibar
42 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 56
