Ana içeriğe geç
Pentax Optio WG-2 Battery Compartment Door Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-6 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: adım 1, 2 resimden 1. Pentax Optio WG-2 Battery Compartment Door Replacement, Back Case: adım 1, 2 resimden 2.
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 Battery Compartment Door Replacement: adım 2, 1 resimden 1.
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 Battery Compartment Door Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 Battery Compartment Door Replacement: adım 4, 3 resimden 1. Pentax Optio WG-2 Battery Compartment Door Replacement: adım 4, 3 resimden 2. Pentax Optio WG-2 Battery Compartment Door Replacement: adım 4, 3 resimden 3.
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 Battery Compartment Door Replacement: adım 5, 1 resimden 1.
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 Battery Compartment Door Replacement: adım 6, 1 resimden 1.
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: adım 7, 3 resimden 1. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: adım 7, 3 resimden 2. Pentax Optio WG-2 Battery Compartment Door Replacement, Battery Compartment Door: adım 7, 3 resimden 3.
    • Lift the cover as you normally would if replacing battery.
    • Holding the camera with the lens facing away from you and the battery slot upward slide the cover towards the back of the camera.
    • There is a pin (3/4 of an inch long) that attaches the cover to the camera and it will come loose when the cover is removed.
Sonuç
Matthew Bessette
658 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 UMass Dartmouth, Team 6-7, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G7
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 872
