Ana içeriğe geç
Pentax Optio WG-2 LCD Screen Replacement
Neye ihtiyacın var
  1. Dikkatli ol: adımlar 1-6 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    Pentax Optio WG-2 LCD Screen Replacement, Back Case: adım 1, 2 resimden 1. Pentax Optio WG-2 LCD Screen Replacement, Back Case: adım 1, 2 resimden 2.
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 LCD Screen Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 LCD Screen Replacement: adım 4, 3 resimden 1. Pentax Optio WG-2 LCD Screen Replacement: adım 4, 3 resimden 2. Pentax Optio WG-2 LCD Screen Replacement: adım 4, 3 resimden 3.
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 1. Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 2.
    • Carefully remove the clear tape covering the screws and the ribbon cable.
    • Be careful not to tear the ribbon cable when removing the tape.
    • We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
  8. Pentax Optio WG-2 LCD Screen Replacement: adım 8, 2 resimden 1. Pentax Optio WG-2 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Once the screen is removed you should have two pieces as seen in the picture.
    • The screen is the silver rectangle in the top of the picture or the component seen in picture two.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Bessette
658 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 UMass Dartmouth, Team 6-7, Bhusal Spring 2016 üyesi
UMASSD-BHUSAL-S16S6G7
3 Üyeler
2Kılavuz Yorumları
Dónde puedo comprar el Display?
Where I can buy the dispaly?
Sebastian Mesa - Yanıt
opération réussie ça marche nickel la plus grosse difficultée est de remettre correctement les 3 connecteurs
impératif: utiliser les bons outils comme indiqué attention aux vis il y a un petit joint et les longueurs différentes ne pas mélanger !!!
merci pour ce super tuto ….
walchkorn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 892
