Pentax Optio WP Back Casing Replacement
Giriş
1. adıma gitThis guide will provide you with step-by-step help for removing the back casing on the Pentax Optio WP Digital Camera.
Neye ihtiyacın var
Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
Firmly push the battery cover to the right and swing open.
The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
With the battery cover swung open, use the spudger to remove the DC IN sticker.
Remove the 4.3 mm silver screw revealed.
Bu adımda kullanılan alet:Tweezers$4.99
Reorient the camera so it is upright and you are looking at the back screen.
Remove the rubber covers in the upper and lower right side corners. Insert spudger in between the camera case and the rubber cover and push them out of their sockets. Grab the rubbers with the tweezers and set them aside. Remove both of the 4.3 mm silver screws revealed.
Remove the 4.3 mm silver screw in the lower left corner which resides under the sliding battery cover.
