Ana içeriğe geç
Pentax Spotmatic Bottom Cover Removal
Sam Gustafson
Sam Gustafson ve başka bir katkıda bulunan
En son December 6, 2024 tarihinde güncellendi
2 dakika
Çok kolay
Topluluk-Katkılı Kılavuz
Sometimes, a jammed camera can be remedied by addressing the mechanisms directly under the bottom cover.
  • If the mirror fails to return after an exposure, causing the viewfinder to black out, try pushing the mirror release lever to the right. This will allow the mirror actuator lever to fall and the mirror to return to the viewing position.
  • If the release button fails to fire the shutter, check the mirror actuator lever, the black bar that travels in the slot. Sometimes it can slip off the release lever between exposures. Push it up until it is caught by the release lever again.
Even though these simple fixes can get your camera shooting again, be aware that they are signs of old and dirty mechanisms. Your camera probably needs a more in depth cleaning in order to perform reliably.
  1. Pentax Spotmatic Bottom Cover Removal, Remove bottom cover: adım 1, 1 resimden 1.
    • Remove two X mm flat head screws.
    • Remove bottom cover.
    • This is an example of a properly functioning mirror charging mechanism.
    • The large gear on the far left is driven by the film advance lever on top of the camera.
    • The long silver lever is the mirror charging lever. It pushes the black bar to the top of the slot when the camera is wound, which charges the main mirror spring.
    • The lever on the right holds the black bar in place while the camera is cocked and ready to shoot.
    • At the end of an exposure, the large black gear pushes the release lever, returning the mirror to the viewing position.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sam Gustafson
7.682 İtibar
42 adet Kılavuz yazıldı
Bir Yorum
Fantastic way of showing how the priming and firing mechanism works. A wonderful post mark
mark steed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 44
Her zaman: 149
