Ana içeriğe geç
Pentax Spotmatic Mirror Box Mechanism Disassembly
Sam Gustafson
Sam Gustafson ve başka bir katkıda bulunan
En son November 27, 2024 tarihinde güncellendi
2 saat
Zor
Topluluk-Katkılı Kılavuz
During an exposure, the mirror box mechanism moves the mirror from the viewing position to the taking position, stops down the lens aperture, then returns the mirror to the viewing position. Over time, old lubrication migrates to unwanted areas, surfaces oxidize and corrode and dirt and grime builds up on moving parts. Eventually, parts may not move as they were intended resulting in various malfunctions. Disassembling and cleaning the mirror box mechanism can resolve issues with winding and stuck mirrors. The following guide will detail the disassembly process and recommend basic cleaning and lubrication methods.
There is some variation in the mirror box mechanisms between Spotmatics from different production runs. Your camera may look slightly different than the one presented here.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove frame counter: adım 1, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove frame counter: adım 1, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove frame counter: adım 1, 3 resimden 3.
    • Loosen three grub screws. Do not remove them from the frame counter cover.
    • Lift off frame counter cover.
    • Remove one 2.5 mm flat head screw. It is reverse or left-hand threaded.
    • Remove the frame counter dial.
    • Remove the retaining nut using a spanner wrench. A pair of fine tipped nippers can also work.
    • On some Spotmatics, this nut may be reverse threaded. Work carefully.
    • Remove the dial seat.
  2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove advance lever: adım 2, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove advance lever: adım 2, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove advance lever: adım 2, 3 resimden 3.
    • Remove three 2.3 mm flat head screws.
    • Use a pick to rotate the retaining washer until the lobed sections are free.
    • Lift off the advance lever.
    • Remove the plastic shim washer.
  3. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove shutter speed dial: adım 3, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove shutter speed dial: adım 3, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove shutter speed dial: adım 3, 3 resimden 3.
    • Remove one 2.8 mm pin head screw.
    • The dial assembly is spring loaded. Keep two fingers on top of the dial as you are loosening the screw to prevent it from popping off.
    • Remove the shutter speed dial.
    • Remove the ISO dial.
    • Remove the internal spring.
    • Remove the dial housing.
  4. Pentax Spotmatic Mirror Box Mechanism Disassembly, Installation Notes: Shutter Speed Dial: adım 4, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Installation Notes: Shutter Speed Dial: adım 4, 2 resimden 2.
    • The hole in the dial housing needs to go over the tab on the speed resistor.
    • The tab on the ISO dial needs to mate with the hole in the dial housing.
    • It can be difficult to line everything up while compressing the spring and installing the center screw. Be patient.
  5. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove film winder assembly: adım 5, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove film winder assembly: adım 5, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove film winder assembly: adım 5, 3 resimden 3.
    • Place a thin, sturdy tool in the spindle fork.
    • Unscrew the rewind knob.
    • Use a spanner wrench to unscrew the retaining nut.
    • Remove the film reminder
    • Remove the spring washer.
    • Remove the friction plate.
  6. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove top cover: adım 6, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove top cover: adım 6, 2 resimden 2.
    • Remove one 3.0 mm flat head screw.
    • Remove top cover.
  7. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove bottom cover: adım 7, 1 resimden 1.
    • Remove two X mm flat head screws.
    • Remove bottom cover.
    • This is an example of a properly functioning mirror charging mechanism.
    • The large gear on the far left is driven by the film advance lever on top of the camera.
    • The long silver lever is the mirror charging lever. It pushes the black bar to the top of the slot when the camera is wound, which charges the main mirror spring.
    • The lever on the right holds the black bar in place while the camera is cocked and ready to shoot.
    • At the end of an exposure, the large black gear pushes the release lever, returning the mirror to the viewing position.
  8. Pentax Spotmatic Mirror Box Mechanism Disassembly, Unsolder meter circuit: adım 9, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Unsolder meter circuit: adım 9, 2 resimden 2.
    • Unscrew or unsolder one black wire. This is the main power coming from the meter switch on the side of the mirror box.
    • Unscrew one blue wire. This is the ground wire that connects the meter circuit to the body of the camera.
    • Unsolder one yellow and one black wire from the speed resistor.
  9. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove viewfinder assembly: adım 10, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove viewfinder assembly: adım 10, 2 resimden 2.
    • Remove three 5.7 mm flat head screws.
    • Lift out the viewfinder assembly.
    • The pentaprism, eye piece and meter circuit will come out with the viewfinder.
  10. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove self timer lever: adım 11, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove self timer lever: adım 11, 2 resimden 2.
    • Remove cover screw using a spanner wrench.
    • Remove the self timer lever. The internal mechanism will unwind past the installed position when the lever is removed.
    • Installation Note: Temporarily place the lever on the post 90° counter-clockwise to its installed position. Wind the self timer. Remove the lever and place it in its installed position. Release the self timer.
  11. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove leatherette: adım 12, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove leatherette: adım 12, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove leatherette: adım 12, 3 resimden 3.
    • Apply isopropyl alcohol to the edge of the leatherette covering to soften the adhesive.
    • Use a dull scraper to get under the edge of the leatherette and begin peeling it off.
    • Fully remove the leatherette covering from both sides of the camera.
    • If the self timer lever can't be removed, the leatherette can be peeled away just enough to access the screws.
    • Installation Note: Use contact cement or shellac to reapply the leatherette.
  12. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove front lens board: adım 13, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove front lens board: adım 13, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove front lens board: adım 13, 3 resimden 3.
    • Remove four 4.6 mm flat head screws.
    • Remove one 4.3 mm flat head screws.
    • Lift off front lens board.
    • Note the position and number of shim washers at each screw location. They need to be installed in the same positions during reassembly.
    • If the top cover is still attached, lift the bottom of the lens board first. There is a lip around the top of the lens mount that engages with the top.
  13. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror return spring: adım 14, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror return spring: adım 14, 2 resimden 2.
    • Unhook mirror return spring.
    • Unscrew one 4.8 mm flat head shoulder screw.
    • Remove keyed washer.
  14. Pentax Spotmatic Mirror Box Mechanism Disassembly, Unsolder wired connections: adım 15, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Unsolder wired connections: adım 15, 2 resimden 2.
    • Unsolder two red wires. These connect to the X-sync contact.
    • Unsolder one black wire. This connects to the battery compartment contact.
    • Pull black meter wire through the whole in the chassis.
  15. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror box: adım 16, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror box: adım 16, 2 resimden 2.
    • Remove one 4.3 mm flat head screw.
    • Remove one 4.5 mm flat head shoulder screw.
    • Lift mirror box up and over posts on the back of the camera. The posts can be removed for easier removal and installation if necessary.
  16. Pentax Spotmatic Mirror Box Mechanism Disassembly, Installation Notes: Mirror Box: adım 17, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Installation Notes: Mirror Box: adım 17, 2 resimden 2.
    • The shutter should be released before installing the mirror box.
    • The mirror charging lever needs to be behind the mirror actuator lever coming from the mirror box.
    • The post from the shutter release shaft should be above the mirror release lever on the mirror box.
  17. Pentax Spotmatic Mirror Box Mechanism Disassembly, Firing the shutter: adım 18, 1 resimden 1.
    • With the mirror box removed, the shutter can be fired by pushing the shutter release bar...
    • and releasing the opening curtain latch
    • A lever on the camera body charges the main mirror spring.
    • The shutter release pushes the mirror release lever.
    • The mirror flips up into the taking position and the stop down plate is pushed forward.
    • The arm extending from the top of the mechanism is the opening curtain striker. It releases the opening curtain latch located on the camera body and begins the exposure of the shutter.
    • The mirror return spring (also on the camera body) pulls the mirror back down to the viewing position.
  18. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove meter and FP sync switch contacts: adım 20, 1 resimden 1.
    • This step is recommended but not necessary. Removing the switch contacts makes it easier to work on the other side of the mirror box without bending them out of shape.
    • Remove two 3.5 mm flat head screws.
    • Remove switch contact board.
  19. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror release latch: adım 21, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror release latch: adım 21, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror release latch: adım 21, 3 resimden 3.
    • Unhook bias spring.
    • Remove one 5.0 mm flat head shoulder screw.
    • Remove shim washer.
    • Remove mirror release latch.
    • Remove bushing.
    • Remove bias spring.
  20. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror lifting lever: adım 22, 2 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror lifting lever: adım 22, 2 resimden 2.
    • Remove one X mm flat head screw.
    • Remove mirror lifting lever.
  21. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror actuator lever: adım 23, 3 resimden 1. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror actuator lever: adım 23, 3 resimden 2. Pentax Spotmatic Mirror Box Mechanism Disassembly, Remove mirror actuator lever: adım 23, 3 resimden 3.
    • Remove one X mm flat head shoulder screw.
    • You may need to hold this screw in the mirror box in place while unscrewing.
    • Note and remove two shim washers.
    • Installation Note: It may be easier to install the actuator lever with the main spring removed. It can be installed after the screw is in place.
Sonuç
Clean all removed parts and mounting points with isopropyl alcohol. High friction surfaces and/or latching points should be lubricated with a thick molybdenum disulfide grease. Quickly moving pivots can be left dry, no further lubrication is necessary.
Sam Gustafson
7.682 İtibar
42 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 59
Her zaman: 305
