Ana içeriğe geç
Petzl E03 050 Headlamp Lens Piece Replacement
Mike
Mike ve 2 diğer katkıda bulunanlar
En son July 29, 2023 tarihinde güncellendi
1 - 2 dakika
Çok kolay
Does your headlamp produce dim lighting despite a fresh set of batteries and a bulb? You may need to replace the lens piece - especially if the reflective mirror has become damaged or dull.
  1. Petzl E03 050 Headlamp Lens Piece Replacement, Extend the Damaged Lens Piece: adım 1, 1 resimden 1.
    • Remove the damaged lens piece by rotating the lens piece counterclockwise (left) until the lens piece is fully extended.
  2. Petzl E03 050 Headlamp Lens Piece Replacement, Remove the Lens Piece: adım 2, 1 resimden 1.
    • Remove the extended lens piece by firmly pulling the lens piece away from the battery housing. Take care to properly dispose of the damaged lens piece.
  3. Petzl E03 050 Headlamp Lens Piece Replacement, Attach the New Lens Piece: adım 3, 1 resimden 1.
    • Attach the new lens piece by firmly pressing the open end of the lens piece onto the battery housing.
  4. Petzl E03 050 Headlamp Lens Piece Replacement, Secure the New Lens Piece: adım 4, 1 resimden 1.
    • Secure the new lens piece onto the battery housing by turning the lens piece clockwise (right) until the headlamp turns on. You have just successfully replaced the lens piece.
Bitiş Çizgisi
Mike
331 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-10, Williams Fall 2014 Baylor, Team 8-10, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G10
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 687
