Giriş
This is a guide on how to replace the speakers on a Philips DS3000/37 Audio Dock. Because this repair requires soldering, the soldering technique page linked here might be helpful. How To Solder and Desolder Connections
Neye ihtiyacın var
Pry off the front fascia by inserting a plastic opening tool between the fascia and white casing.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
i hardly difficult to treat 2 defective speakers. i find the flat cable a little loose on the main plate. thank you!!!
