Ana içeriğe geç
Philips Norelco 5801XL Battery Replacement
Neye ihtiyacın var
  1. Philips Norelco 5801XL Battery Replacement, Battery: adım 1, 2 resimden 1. Philips Norelco 5801XL Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Using a T8 torx screwdriver, remove both 2mm T8 screws.
  2. Philips Norelco 5801XL Battery Replacement: adım 2, 2 resimden 1. Philips Norelco 5801XL Battery Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, separate the front housing from the back housing.
    • Carefully pull the housing apart.
  3. Philips Norelco 5801XL Battery Replacement: adım 3, 3 resimden 1. Philips Norelco 5801XL Battery Replacement: adım 3, 3 resimden 2. Philips Norelco 5801XL Battery Replacement: adım 3, 3 resimden 3.
    • Remove the plastic bracket using a plastic opening tool.
    • Pry from the inside of the bracket towards the outside of the housing to remove it.
  4. Philips Norelco 5801XL Battery Replacement: adım 4, 1 resimden 1.
    • Remove the two T8 2mm Philips screws holding onto the bracket over the charge port.
    • Remove the bracket. It will pull straight out.
  5. Philips Norelco 5801XL Battery Replacement: adım 5, 1 resimden 1.
    • Push in the charge port using the plastic opening tool.
  6. Philips Norelco 5801XL Battery Replacement: adım 6, 1 resimden 1.
    • Lift the circuit board upwards and fold it towards the head of the razor.
    • Do not break the contacts connecting the board to the motor.
  7. Philips Norelco 5801XL Battery Replacement: adım 7, 3 resimden 1. Philips Norelco 5801XL Battery Replacement: adım 7, 3 resimden 2. Philips Norelco 5801XL Battery Replacement: adım 7, 3 resimden 3.
    • Desolder the contacts where the battery connects to the circuit board.
    • Straighten the battery contacts and pull them through the opposite side of the circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ben Gibbs
361 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-2, Harley Spring 2016 IUPUI, Team 3-2, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S3G2
4 Üyeler
6 adet Kılavuz yazıldı
3 Yorum
The replacement battery I bought had contact strips that were too long and too wide for the slots on the circuit board, so I had to trim off about half the length and 1.5 mm of the width on each strip, but after that alteration, it worked fine.
Tom Hess - Yanıt
What size is the Rechargeable Battery in the Norelco 5801XL .
Dave - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 4,387
