Ana içeriğe geç
Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
August Post
August Post ve başka bir katkıda bulunan
En son July 15, 2024 tarihinde güncellendi
20 dakika
Orta
This guide will show how to take off a broken LED board, and replace it with a new one. You may need this if you notice the charging light on the Philips Norelco Bodygroom not lighting up while the product is on the charging stand. It is also necessary for this guide to show how to disassemble and reassemble the trimmer in order to get to the LED board. It is recommended to have the iFixit Pro Tech Toolkit since it will contain all tools necessary for this guide. Lastly, you will need to provide your own working LED board to replace the broken one.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: adım 1, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: adım 1, 2 resimden 2.
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 2, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 2, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 2, 3 resimden 3.
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 3, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 3, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 3, 3 resimden 3.
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 4, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 4, 2 resimden 2.
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 5, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 5, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 5, 3 resimden 3.
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 6, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 6, 2 resimden 2.
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 7, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 7, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 7, 3 resimden 3.
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
August Post
415 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G4
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 20
Her zaman: 604
