Ana içeriğe geç
Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement
August Post
August Post ve başka bir katkıda bulunan
En son July 15, 2024 tarihinde güncellendi
10 dakika
Orta
This guide will show how to take out both trimmer blades, and replace them with a new ones. You may need this if the trimmer blades on the Philips Norelco Bodygroom break, or for some reason become too dull to use. It is also necessary for this guide to show how to disassemble and reassemble the trimmer head in order to get to the blades. It is recommended to have the iFixit Pro Tech Toolkit since it will contain all tools necessary for this guide. Lastly, you will need to provide your own working blades to replace the broken ones.
Neye ihtiyacın var
Aletler
  • Spudger
    Spudger
  1. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: adım 1, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement, Trimmer Head Blades: adım 1, 2 resimden 2.
    • Pop open the trimmer head by pushing against the blades.
    • Slide off trimmer guard and open the hatch on the side.
    • Remove the trimmer from the base.
  2. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: adım 2, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Trimmer Head Blades Replacement: adım 2, 2 resimden 2.
    • Remove spring first, and then pull off white plastic along with the first, moving blade.
    • Use spudger to pry off second, stationary blade.
Sonuç
Bir başkası bu kılavuzu tamamladı.
August Post
415 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G4
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
How do you reattach the spring?
Antonio Chrysokhou - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 37
Her zaman: 3,819
