Ana içeriğe geç
Philips Norelco MultiGroom 3100 Motor Replacement
Neye ihtiyacın var
  1. Philips Norelco MultiGroom 3100 Motor Replacement, Power Button: adım 1, 1 resimden 1.
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Motor Replacement: adım 2, 2 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement: adım 2, 2 resimden 2.
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Motor Replacement: adım 3, 2 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement: adım 3, 2 resimden 2.
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Motor Replacement: adım 4, 1 resimden 1.
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Motor Replacement, Casing: adım 5, 2 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement, Casing: adım 5, 2 resimden 2.
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Motor Replacement: adım 6, 2 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement: adım 6, 2 resimden 2.
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
  7. Philips Norelco MultiGroom 3100 Motor Replacement, Motor: adım 7, 2 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement, Motor: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the tweezers to pull out the inner power button.
  8. Philips Norelco MultiGroom 3100 Motor Replacement: adım 8, 1 resimden 1.
    • Use the plastic opening tool to separate the clip on the right side of the inner housing.
  9. Philips Norelco MultiGroom 3100 Motor Replacement: adım 9, 2 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement: adım 9, 2 resimden 2.
    • Push the inner housing up and to the right to separate the left clip from the battery casing.
    • Push the inner housing upwards to separate it from the battery casing.
  10. Philips Norelco MultiGroom 3100 Motor Replacement: adım 10, 2 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement: adım 10, 2 resimden 2.
    • Use the tweezers to hold the wire steady as you unsolder the blue wire from the power switch.
    • Use the tweezers to remove the power switch.
    • For help with soldering check out the iFixit Soldering Technique Guide.
  11. Philips Norelco MultiGroom 3100 Motor Replacement: adım 11, 3 resimden 1. Philips Norelco MultiGroom 3100 Motor Replacement: adım 11, 3 resimden 2. Philips Norelco MultiGroom 3100 Motor Replacement: adım 11, 3 resimden 3.
    • Pull up on the motor to remove it from the battery casing.
    • Use the tweezers to hold the black wire steady while unsoldering it from the base of the battery.
    • Using the tweezers, pull on the black wire to remove it from the base of the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
ahaharevolution
759 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Fall 2015 USF Tampa, Team 1-1, Leahy Fall 2015 üyesi
USFT-LEAHY-F15S1G1
2 Üyeler
4 Yorum
¿Me puedes ayudar con algo?
Johan Avendaño - Yanıt
Can you help me with something?
this guide was created also by nina lovekrist in 2015
Nina Lovekrist - Yanıt
Where can I get the motor with copper shaft?
amal.hardik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 4,675
