Ana içeriğe geç
Philips Respironics V60 Alarm Speaker Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Philips Respironics V60 Alarm Speaker Replacement, Alarm Speaker: adım 1, 1 resimden 1.
    • step 1 Remove MC PCBA
    • Remove top cover (top cover guide here)
    • Remove the screws and wing nuts that attach the MC PCBA to the PCBA brackets.
    • Loosen the captive screws that attach the capacitor bracket to the base.
    • Disconnect cables: • Blower cable • Fan cable • DA-MC ribbon cable
    • Gently pull MC PCBA up from its connection on the CPU PCBA, then disconnect speaker #1 cable.
    • Remove PCBA brackets. To reinstall, follow the steps above in reverse order
  2. Philips Respironics V60 Alarm Speaker Replacement: adım 2, 1 resimden 1.
    • step 2 separate the UI from the base
    • Remove MC PCBA (step 1)
    • Disconnect cables: • LCD cable from PM PCBA. • LCD cable ground wires from the ground terminal. • LCD tray ground wires from the ground terminal. • UI cable (ribbon cable) from the PM PCBA.
    • Loosen the captive screw that attaches the UI retainer to the UI.
    • Slide retainer up, then remove UI from base.
  3. Philips Respironics V60 Alarm Speaker Replacement: adım 3, 1 resimden 1.
    • step 3 remove the front panel
    • Separate UI from base (step 2)
    • Remove hose clamp and boot that attach blower to the gas outlet.
    • Remove the tubing from the barbed fittings inside the front panel.
    • Disconnect gas outlet and proximal port ground wires from the base.
    • Remove the screws that attach the front panel to the base and side walls.
    • NOTE: When reinstalling tubing, ensure that: • Longer (9-in.) tube is connected between manifold barb “M” (machine) to barbed gas outlet fitting. • Shorter (8-in.) tube is connected between manifold barb “P” (proximal) and barbed proximal pressure port.
  4. Philips Respironics V60 Alarm Speaker Replacement: adım 4, 1 resimden 1.
    • step 4 remove the alarm speakers
    • Remove front panel (step 3)
    • Disconnect speaker #2 from the power management (PM) PCBA. (Speaker #1 is disconnected when the MC PCBA is disconnected.)
    • Remove the screw and washer that attaches each speaker to the base.
    • Insert new speaker in place of old one
    • Follow step 4 in reverse order to install speaker.
    • step 5 reinstalling
    • Follow step 3 in reverse order to reinstall the front panel.
    • Follow step 2 in reverse order to reinstall the UI to the base.
    • Follow step 1 in reverse order to reinstall the MC PCBA.
    • Follow the Top Cover Guide in reverse order to reinstall.
Sonuç
Weihan Du
241 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G10
2 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 503
