Ana içeriğe geç
Philips Satinelle Disassembly
Neye ihtiyacın var
  1. Philips Satinelle Disassembly, Philips Satinelle Disassembly: adım 1, 2 resimden 1. Philips Satinelle Disassembly, Philips Satinelle Disassembly: adım 1, 2 resimden 2.
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Disassembly: adım 2, 3 resimden 1. Philips Satinelle Disassembly: adım 2, 3 resimden 2. Philips Satinelle Disassembly: adım 2, 3 resimden 3.
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Disassembly: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Disassembly: adım 4, 3 resimden 1. Philips Satinelle Disassembly: adım 4, 3 resimden 2. Philips Satinelle Disassembly: adım 4, 3 resimden 3.
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Disassembly: adım 5, 3 resimden 1. Philips Satinelle Disassembly: adım 5, 3 resimden 2. Philips Satinelle Disassembly: adım 5, 3 resimden 3.
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Disassembly: adım 6, 3 resimden 1. Philips Satinelle Disassembly: adım 6, 3 resimden 2. Philips Satinelle Disassembly: adım 6, 3 resimden 3.
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Disassembly: adım 7, 3 resimden 1. Philips Satinelle Disassembly: adım 7, 3 resimden 2. Philips Satinelle Disassembly: adım 7, 3 resimden 3.
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Nathan Christian
505 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G5, Wilson Fall 2017 IUPUI, Team S5-G5, Wilson Fall 2017 üyesi
IUPUI-WILSON-F17S5G5
3 Üyeler
8 adet Kılavuz yazıldı
6Kılavuz Yorumları
can we open the lower part which holds the motor and gear..
actualy the gear which holds the motor is gone bad i think.. so i want to replace it ..
can this be fixed..??
Md Wasim Anwar - Yanıt Paylaş
Same here .. wanted to open the bottom part which holds a longish gear .. the top gear fits in a very small portion of the bottom long gear so the long gear has worn out in just that area
S Ahooja - Yanıt Paylaş
similar here, wanted to open the lower part where the cable goes in. the cable is broken at the entry.
frankgerling - Yanıt Paylaş
To open main body …Click here
Philips Satinelle Motor Replacement
ted_duggan - Yanıt Paylaş
Thank you for this great tutorial. It really helps!
Can you please give us the dimensions for the gear’s teeth in step 7 and the corresponding gear in step 2 in the Philips Satinelle Motor Replacement tutorial? I can 3D print the gears, but I can’t find the dimensions online and the gears are simply to eroded to be able to measure them.
Albert Westhoff - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 97
Her zaman: 10,357
