Ana içeriğe geç
Philips Satinelle Gear Replacement
Neye ihtiyacın var
  1. Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: adım 1, 2 resimden 1. Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: adım 1, 2 resimden 2.
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Gear Replacement: adım 2, 3 resimden 1. Philips Satinelle Gear Replacement: adım 2, 3 resimden 2. Philips Satinelle Gear Replacement: adım 2, 3 resimden 3.
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Gear Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Gear Replacement: adım 4, 3 resimden 1. Philips Satinelle Gear Replacement: adım 4, 3 resimden 2. Philips Satinelle Gear Replacement: adım 4, 3 resimden 3.
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Gear Replacement: adım 5, 3 resimden 1. Philips Satinelle Gear Replacement: adım 5, 3 resimden 2. Philips Satinelle Gear Replacement: adım 5, 3 resimden 3.
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Gear Replacement: adım 6, 3 resimden 1. Philips Satinelle Gear Replacement: adım 6, 3 resimden 2. Philips Satinelle Gear Replacement: adım 6, 3 resimden 3.
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Gear Replacement: adım 7, 3 resimden 1. Philips Satinelle Gear Replacement: adım 7, 3 resimden 2. Philips Satinelle Gear Replacement: adım 7, 3 resimden 3.
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Gear Replacement, Gear Replacement: adım 8, 1 resimden 1.
    • Replace the gear and re-insert the pin.
    • Ensure that pin is protruding slightly, it should not be flush.
Sonuç
Nathan Christian
505 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G5, Wilson Fall 2017 IUPUI, Team S5-G5, Wilson Fall 2017 üyesi
IUPUI-WILSON-F17S5G5
3 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
What size pinion is used in it? Kindly help.
Wilkis James - Yanıt
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
Emilio Hernandez - Yanıt
Tienes las medidas de los engranajes
luis vega - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 1,653
