Ana içeriğe geç
Philips Somneo LED Assembly Replacement
Neye ihtiyacın var
  1. Philips Somneo LED Assembly Replacement, Antenna: adım 1, 1 resimden 1.
    • Remove the four silicone feet on the bottom plate.
    • Remove the following Phillips screws from the bottom plate:
    • Two 9 mm screws
    • Two 13 mm screws
  2. Philips Somneo LED Assembly Replacement: adım 2, 2 resimden 1. Philips Somneo LED Assembly Replacement: adım 2, 2 resimden 2.
    • Remove the bottom plate from the device.
  3. Philips Somneo LED Assembly Replacement: adım 3, 2 resimden 1. Philips Somneo LED Assembly Replacement: adım 3, 2 resimden 2.
    • Disconnect the antenna connector by pulling it directly out of its port.
    • Remove the antenna.
  4. Philips Somneo LED Assembly Replacement, Motherboard: adım 4, 2 resimden 1. Philips Somneo LED Assembly Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the four 9 mm Phillips screws securing the motherboard.
  5. Philips Somneo LED Assembly Replacement: adım 5, 2 resimden 1. Philips Somneo LED Assembly Replacement: adım 5, 2 resimden 2.
    • Gently pull the motherboard down until the cables are visible.
    • Take care not to strain the connected cables.
  6. Philips Somneo LED Assembly Replacement: adım 6, 3 resimden 1. Philips Somneo LED Assembly Replacement: adım 6, 3 resimden 2. Philips Somneo LED Assembly Replacement: adım 6, 3 resimden 3.
    • Remove each cord by gently disconnecting each connector with your hand.
  7. Philips Somneo LED Assembly Replacement: adım 7, 3 resimden 1. Philips Somneo LED Assembly Replacement: adım 7, 3 resimden 2. Philips Somneo LED Assembly Replacement: adım 7, 3 resimden 3.
    • Continue gently removing each cord with you hand.
  8. Philips Somneo LED Assembly Replacement: adım 8, 2 resimden 1. Philips Somneo LED Assembly Replacement: adım 8, 2 resimden 2.
    • Finish gently removing the final cord attached to the motherboard to successfully remove the motherboard.
  9. Philips Somneo LED Assembly Replacement, LED Assembly: adım 9, 3 resimden 1. Philips Somneo LED Assembly Replacement, LED Assembly: adım 9, 3 resimden 2. Philips Somneo LED Assembly Replacement, LED Assembly: adım 9, 3 resimden 3.
    • Use an opening pick to pry underneath the plastic covering the edges of the screen.
    • Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
  10. Philips Somneo LED Assembly Replacement: adım 10, 2 resimden 1. Philips Somneo LED Assembly Replacement: adım 10, 2 resimden 2.
    • The panel should be loosened significantly enough to be pulled off the main body, revealing the edges of the screen.
  11. Philips Somneo LED Assembly Replacement: adım 11, 2 resimden 1. Philips Somneo LED Assembly Replacement: adım 11, 2 resimden 2.
    • Remove the two 13 mm Phillips #0 screws on the bottom edges of the screen.
    • Remove the 9 mm Phillips #0 screws on the upper edge of the screen.
  12. Philips Somneo LED Assembly Replacement: adım 12, 3 resimden 1. Philips Somneo LED Assembly Replacement: adım 12, 3 resimden 2. Philips Somneo LED Assembly Replacement: adım 12, 3 resimden 3.
    • Remove the display assembly.
  13. Philips Somneo LED Assembly Replacement: adım 13, 3 resimden 1. Philips Somneo LED Assembly Replacement: adım 13, 3 resimden 2. Philips Somneo LED Assembly Replacement: adım 13, 3 resimden 3.
    • On the back of the screen, remove the four 9 mm Phillips #00 screws, disconnecting the LED assembly.
  14. Philips Somneo LED Assembly Replacement: adım 14, 3 resimden 1. Philips Somneo LED Assembly Replacement: adım 14, 3 resimden 2. Philips Somneo LED Assembly Replacement: adım 14, 3 resimden 3.
    • Two cables connected to the LED were once connected to the motherboard, but are still attached to the body. They are threaded through black ovals connected to the body by a hard black adhesive.
    • Using a metal spudger, scrape underneath this adhesive and pry up, freeing the cable from the body. Repeat this for the other cable to free the LED.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Ryan Borges
213 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Botvin Spring 2025 UMass Dartmouth, Team 6-1, Botvin Spring 2025 üyesi
UMASSD-BOTVIN-S25S6G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 99
