Ana içeriğe geç
Philips Sonicare DiamondClean Circuit Board Replacement
Neye ihtiyacın var
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: adım 1, 2 resimden 1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: adım 1, 2 resimden 2.
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: adım 2, 1 resimden 1.
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: adım 3, 3 resimden 1. Philips Sonicare DiamondClean Circuit Board Replacement: adım 3, 3 resimden 2. Philips Sonicare DiamondClean Circuit Board Replacement: adım 3, 3 resimden 3.
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: adım 4, 1 resimden 1.
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: adım 5, 1 resimden 1.
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: adım 6, 1 resimden 1.
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 72
Her zaman: 2,692
