Ana içeriğe geç
Photive Rain Battery Replacement
Neye ihtiyacın var
  1. Photive Rain Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
    FixBot'a Sor
    Yorum Ekle
  2. Photive Rain Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
    FixBot'a Sor
    Yorum Ekle
  3. Photive Rain Battery Replacement, Battery: adım 3, 2 resimden 1. Photive Rain Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
    FixBot'a Sor
    Yorum Ekle
  4. Photive Rain Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
abcdef ghijk
723 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2016 IUPUI, Team 1-4, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S1G4
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 801
