Ana içeriğe geç
Photive Rain Motherboard Replacement
Neye ihtiyacın var
  1. Photive Rain Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Motherboard Replacement, Battery: adım 3, 2 resimden 1. Photive Rain Motherboard Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
  4. Photive Rain Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
  5. Photive Rain Motherboard Replacement, Speaker: adım 5, 1 resimden 1.
    • Carefully remove the front panel from the device.
  6. Photive Rain Motherboard Replacement: adım 6, 1 resimden 1.
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  7. Photive Rain Motherboard Replacement: adım 7, 2 resimden 1. Photive Rain Motherboard Replacement: adım 7, 2 resimden 2.
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
  8. Photive Rain Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • From the back of the motherboard, unscrew the three phillips head screws holding the motherboard in place.
  9. Photive Rain Motherboard Replacement: adım 9, 1 resimden 1.
    • Pull the rubber away from the edge of the motherboard.
  10. Photive Rain Motherboard Replacement: adım 10, 2 resimden 1. Photive Rain Motherboard Replacement: adım 10, 2 resimden 2.
    • Use the plastic opening tool to remove motherboard from device.
    • The second photograph displays a properly removed motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
abcdef ghijk
723 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2016 IUPUI, Team 1-4, Harley Spring 2016 üyesi
IUPUI-HARLEY-S16S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 292
