Ana içeriğe geç
Pine64 PinePhone Front and Rear Camera Replacement
Neye ihtiyacın var
  1. Pine64 PinePhone Front and Rear Camera Replacement, Place the device facing down: adım 1, 2 resimden 1. Pine64 PinePhone Front and Rear Camera Replacement, Place the device facing down: adım 1, 2 resimden 2.
    • Place the device face down on a non-scratch surface.
    • Ensure the device is powered off before removing the case as removing the battery or making internal changes could cause physical or hardware damage to the phone
  2. Pine64 PinePhone Front and Rear Camera Replacement, Remove the back cover: adım 2, 1 resimden 1.
    • Using a fingernail pry open the back cover off with the bottom left indent.
    • A notch to easily remove the cover is located at the bottom left of the PinePhone with the back cover facing the user.
  3. Pine64 PinePhone Front and Rear Camera Replacement, Battery: adım 3, 1 resimden 1.
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Front and Rear Camera Replacement, Motherboard: adım 4, 1 resimden 1.
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Front and Rear Camera Replacement: adım 5, 1 resimden 1.
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Front and Rear Camera Replacement: adım 6, 1 resimden 1.
    • Use a spudger to lift the motherboard up and remove it from the device.
  7. Pine64 PinePhone Front and Rear Camera Replacement, Front and Rear Camera: adım 7, 1 resimden 1.
    • Use a spudger to remove the rear camera.
  8. Pine64 PinePhone Front and Rear Camera Replacement: adım 8, 1 resimden 1.
    • Use a spudger to remove the front camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 508
