Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the headset face down.
Squeeze both sides of the battery cover.
While squeezing, pull the cover up slowly to remove it.
Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
Apply additional heat at the tip of the microphone.
After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
Use the plastic opening tool to separate the speaker casing from the headset face.
Slowly separate the motherboard from the rest of the headset.
Locate the microphone wires on the bottom of the motherboard.
Flip the device over.
Use a soldering iron to remove the solder that holds the wires to the motherboard.
