Ana içeriğe geç
PlayStation 4 Pro Heat Pipe Replacement
Neye ihtiyacın var
  1. PlayStation 4 Pro Heat Pipe Replacement, Hard Drive Caddy: adım 1, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement, Hard Drive Caddy: adım 1, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement, Hard Drive Caddy: adım 1, 3 resimden 3.
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Heat Pipe Replacement: adım 2, 2 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Heat Pipe Replacement, Power Supply Assembly: adım 3, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement, Power Supply Assembly: adım 3, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement, Power Supply Assembly: adım 3, 3 resimden 3.
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Heat Pipe Replacement: adım 4, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 4, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement: adım 4, 3 resimden 3.
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
  5. PlayStation 4 Pro Heat Pipe Replacement: adım 5, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 5, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement: adım 5, 3 resimden 3.
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  6. PlayStation 4 Pro Heat Pipe Replacement: adım 6, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 6, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement: adım 6, 3 resimden 3.
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  7. PlayStation 4 Pro Heat Pipe Replacement: adım 7, 2 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 7, 2 resimden 2.
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
  8. PlayStation 4 Pro Heat Pipe Replacement: adım 8, 2 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 8, 2 resimden 2.
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
  9. PlayStation 4 Pro Heat Pipe Replacement: adım 9, 1 resimden 1.
    • Pull up and remove the metal plate.
  10. PlayStation 4 Pro Heat Pipe Replacement: adım 10, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 10, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement: adım 10, 3 resimden 3.
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
  11. PlayStation 4 Pro Heat Pipe Replacement, Motherboard: adım 11, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement, Motherboard: adım 11, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement, Motherboard: adım 11, 3 resimden 3.
    • If you are working on the 7200-series model, this metal plate will have been already removed as part of the removing the larger motherboard plate. You may skip this step if this is the case.
    • Carefully flip the console over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
    • Use a plastic opening tool to remove the metal plate with the X-like shape.
  12. PlayStation 4 Pro Heat Pipe Replacement: adım 12, 3 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 12, 3 resimden 2. PlayStation 4 Pro Heat Pipe Replacement: adım 12, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
    • For 7200-series models this is instead a S-shaped metal plate with 2 screws.
    • Grip the X-shaped retaining bracket and lift straight up.
  13. PlayStation 4 Pro Heat Pipe Replacement: adım 13, 2 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 13, 2 resimden 2.
    • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
    • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
  14. PlayStation 4 Pro Heat Pipe Replacement, Heat Pipe: adım 14, 2 resimden 1. PlayStation 4 Pro Heat Pipe Replacement, Heat Pipe: adım 14, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 6 mm silver screws from the metal plate.
  15. PlayStation 4 Pro Heat Pipe Replacement: adım 15, 2 resimden 1. PlayStation 4 Pro Heat Pipe Replacement: adım 15, 2 resimden 2.
    • Lift the metal plate that is connected to the heat pipe straight up to remove it.
Sonuç
42 farklı kişi bu kılavuzu tamamladı.
Thomas
3.877 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G5, Livingston Spring 2017 Cal Poly, Team S21-G5, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S21G5
4 Üyeler
49 adet Kılavuz yazıldı
3 Yorum
Ist es schlimm, wenn man die 2 schrauben von schritt 14 vergessen hat zum verschrauben?
AxoN z - Yanıt
Can anyone explain what are those 5 blocks near heatsink as mine are broken when I open it 2 blocks have converted into dust plz help
rajatagg41 - Yanıt
This guide doesn't tell how to change the Heat Pipe on the later models. In my 72xx version, the Heat Pipe can be seperated from the chassis plating with 4 screws (ph#1)
TdG - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 105
Son 30 gün: 488
Her zaman: 65,354
