Ana içeriğe geç
PlayStation 4 Thermal Paste Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. PlayStation 4 Thermal Paste Replacement, Remove the hard drive cover: adım 1, 3 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the hard drive cover: adım 1, 3 resimden 2. PlayStation 4 Thermal Paste Replacement, Remove the hard drive cover: adım 1, 3 resimden 3.
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. PlayStation 4 Thermal Paste Replacement, Remove the hard drive bracket screw: adım 2, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the hard drive bracket screw: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
  3. PlayStation 4 Thermal Paste Replacement, Remove the hard drive bracket: adım 3, 3 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the hard drive bracket: adım 3, 3 resimden 2. PlayStation 4 Thermal Paste Replacement, Remove the hard drive bracket: adım 3, 3 resimden 3.
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
  4. PlayStation 4 Thermal Paste Replacement, Flip over the PS4: adım 4, 1 resimden 1.
    • Flip the PS4 upside-down with the back side facing towards you.
  5. PlayStation 4 Thermal Paste Replacement, Remove the warranty stickers: adım 5, 3 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the warranty stickers: adım 5, 3 resimden 2. PlayStation 4 Thermal Paste Replacement, Remove the warranty stickers: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  6. PlayStation 4 Thermal Paste Replacement, Remove the plastic screw covers: adım 6, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the plastic screw covers: adım 6, 2 resimden 2.
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  7. PlayStation 4 Thermal Paste Replacement, Remove the rear case screws: adım 7, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the rear case screws: adım 7, 2 resimden 2.
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  8. PlayStation 4 Thermal Paste Replacement, Remove the lower case: adım 8, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the lower case: adım 8, 2 resimden 2.
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  9. PlayStation 4 Thermal Paste Replacement: adım 9, 2 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 9, 2 resimden 2.
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  10. PlayStation 4 Thermal Paste Replacement, Remove the power supply unit: adım 10, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the power supply unit: adım 10, 2 resimden 2.
    • Remove three 9.7 mm-long TR8 Torx security screws.
    • Remove two 41 mm-long Phillips screws and brackets.
  11. PlayStation 4 Thermal Paste Replacement: adım 11, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 11, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 11, 3 resimden 3.
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
  12. PlayStation 4 Thermal Paste Replacement, Remove the Wi-Fi antenna: adım 12, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the Wi-Fi antenna: adım 12, 2 resimden 2.
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  13. PlayStation 4 Thermal Paste Replacement: adım 13, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 13, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 13, 3 resimden 3.
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  14. PlayStation 4 Thermal Paste Replacement: adım 14, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 14, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 14, 3 resimden 3.
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  15. PlayStation 4 Thermal Paste Replacement: adım 15, 2 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 15, 2 resimden 2.
    • Remove the 9.7 mm Torx security screw securing the antenna.
  16. PlayStation 4 Thermal Paste Replacement: adım 16, 2 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 16, 2 resimden 2.
    • Remove the Wi-Fi antenna.
  17. PlayStation 4 Thermal Paste Replacement, Disconnect the optical drive: adım 17, 3 resimden 1. PlayStation 4 Thermal Paste Replacement, Disconnect the optical drive: adım 17, 3 resimden 2. PlayStation 4 Thermal Paste Replacement, Disconnect the optical drive: adım 17, 3 resimden 3.
    • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
    • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
    • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
  18. PlayStation 4 Thermal Paste Replacement: adım 18, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 18, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 18, 3 resimden 3.
    • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
    • Set the ribbon cable aside for reassembly.
  19. PlayStation 4 Thermal Paste Replacement: adım 19, 2 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 19, 2 resimden 2.
    • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
  20. PlayStation 4 Thermal Paste Replacement: adım 20, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 20, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 20, 3 resimden 3.
    • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
  21. PlayStation 4 Thermal Paste Replacement, Remove the optical drive: adım 21, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the optical drive: adım 21, 2 resimden 2.
    • Remove the four screws securing the optical drive.
    • Three 9.7 mm Torx screws
    • One 6.2 mm Phillips screw
  22. PlayStation 4 Thermal Paste Replacement: adım 22, 2 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 22, 2 resimden 2.
    • Lift the optical drive straight up and out of the PS4.
  23. PlayStation 4 Thermal Paste Replacement, Remove the upper case: adım 23, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the upper case: adım 23, 2 resimden 2.
    • Remove the two 9.7 mm Torx screws securing the upper case.
  24. PlayStation 4 Thermal Paste Replacement: adım 24, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 24, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 24, 3 resimden 3.
    • Lift the upper case up and back to remove it from the PS4.
    • The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
  25. PlayStation 4 Thermal Paste Replacement, Remove the upper EMI shield: adım 25, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the upper EMI shield: adım 25, 2 resimden 2.
    • Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
  26. PlayStation 4 Thermal Paste Replacement: adım 26, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 26, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 26, 3 resimden 3.
    • This step shows you how to properly unscrew the pressure plate.
    • Remove the two 15.6 mm Phillips screws.
    • Gradually unscrew the pressure plate by turning each screw one half turn at a time.
    • Alternate between the two screws to maintain even pressure on the pressure plate.
    • Do not unscrew one side completely before unscrewing the other side or you may damage the processor.
  27. PlayStation 4 Thermal Paste Replacement: adım 27, 1 resimden 1.
    • Remove the pressure plate.
  28. PlayStation 4 Thermal Paste Replacement: adım 28, 2 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 28, 2 resimden 2.
    • Remove the upper EMI shield.
  29. PlayStation 4 Thermal Paste Replacement, Remove the motherboard: adım 29, 2 resimden 1. PlayStation 4 Thermal Paste Replacement, Remove the motherboard: adım 29, 2 resimden 2.
    • Insert the flat end of a spudger in between the fan cable and the motherboard.
    • Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
  30. PlayStation 4 Thermal Paste Replacement: adım 30, 2 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 30, 2 resimden 2.
    • Grab the edge of the motherboard on the front of the PS4.
    • Lift the motherboard until the USB ports clear the PS4 case.
  31. PlayStation 4 Thermal Paste Replacement: adım 31, 3 resimden 1. PlayStation 4 Thermal Paste Replacement: adım 31, 3 resimden 2. PlayStation 4 Thermal Paste Replacement: adım 31, 3 resimden 3.
    • Lift the motherboard out from the PS4.
    • Apply a new layer of thermal paste to the processor before installing a motherboard using this guide.
    • Failure to properly install new thermal paste will cause your PS4 to overheat.
    • Insert the I/O side of the Motherboard in first, then lower the other side in.
  32. PlayStation 4 Thermal Paste Replacement, Clean Off Existing Thermal Paste: adım 32, 3 resimden 1. PlayStation 4 Thermal Paste Replacement, Clean Off Existing Thermal Paste: adım 32, 3 resimden 2. PlayStation 4 Thermal Paste Replacement, Clean Off Existing Thermal Paste: adım 32, 3 resimden 3.
    • Using tissue paper, wipe off the existing thermal paste. Take the new thermal paste and apply a small amount to the middle of the component.
    • Make sure to clean the thermal paste from both ends.
Sonuç
175 farklı kişi bu kılavuzu tamamladı.
Alyasin Hossain
2.230 İtibar
1 Kılavuz yazıldı
Ekip
23Kılavuz Yorumları
Se me hizo muy buena la guia, sobre todo para no cometer algun error al trabajar en la reparacion, mi PS4 dejo de zumbar el abanico con el cambio de pasta termica y una limpieza general de polvo y pelusa.
Luis Garcia - Yanıt
I followed this guide step by step, including reversing the order to reassemble my unit.
My PS4 is still loud but not as loud as before, so everything worked well. Thanks for the writeup!
Billy P - Yanıt
i might be a little late to reply, but i followed this guide aswell BUT after step 31 i took off the extra metal/aluminum plating and saw thats that where the bulk of the dust will be built up, this plate has the vents that go to the cooling fan on the opposite side of it after unscrewing. i bought an original ps4, it sounded like a jet engine taking off. The vents on my ps4 were just about covered in dust almost no airflow was able to get through, after taking the extra step and taking off the 1 extra panel (the one under the motherboard in step 31) and of course after replacing the thermal paste made my ps4 run and sound like new again,
Beau -
I cannot reply to Beau's comment.
I also went the extra step of taking that metal shroud that sits below the motherboard (step 31).
I completely recommend this step. It is then you can get access to the heat sink fins to remove dust. There are 3 screws that hold this metal shroud in place. Easy to get out.
Then you can also now remove the fan - 2 screws for this.
You can then clean out the accumulated dust from the fan and in the plastic shroud, that the fan sits in.
Holy cow, dust factory. :)
Cary B - Yanıt
Great guide! Just did it and now the console is dead silent during gameplay of super demanding games <3 I just went a step further after Step 31 and removed the plate there so that I could properly take care of the heat sink underneath that had lots of dust on it.
Sébastien Morin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 134
Son 7 gün: 963
Son 30 gün: 4,851
Her zaman: 299,017
